07-24-2003, 03:40 AM
#1
BMW again.
Car: 1994 325is
LOL- gauge problem
well not minutes after reading jeremys problem , i got one, what happens is the gauge cluster sometimes shuts down, no gas , kilometers, rpm, temp, or odometer, but all other lights work, then by itself they come on , then later will go off, then on , then off, so on and so forth. what the hell could be doing this>? thanks guys.
07-24-2003, 03:50 AM
#2
Car: Dodge Ram
sounds like we're both fuked
07-24-2003, 03:59 AM
#3
BMW again.
Car: 1994 325is
yup
07-24-2003, 04:17 AM
#4
Car: e30 325
i just joined the club......all my gauges are dead except for the speedometer. I'm going to be taking out the instrument cluster again (1st time was to install white gauges) this weekend. I suspect either the metal contact is dirty or one of those colored plug units at the back (i think there are 4) of the cluster are loose.
I'll keep y'all posted.
07-24-2003, 08:45 PM
#5
Gets Blown Daily
Car: 1994 333HP Supercharged Project E36, 1996 Hummer H1
If you're sure it's not a fuse or a loose/broken wire/connection then take it apart and look for blown capacitors, resistors, or even solder connections that may have come undone.
Any electronics repair shop can fix it, or if you're in the area, I could fix it.
Mods
-Shortstack headers
-Vortech RRFPR
-255LPH Walbro fuel pump
-Keskin KT1 17x8.5 & 17x10
-Remus full catback
-SMT6 EMS (Untuned)
07-24-2003, 10:40 PM
#6
BMW again.
Car: 1994 325is
DJ you hit the nail on the head. i think its a blown cap. i pulled the assembly apart and no problems on the surface as far as sodder goes. the fuses were all changed. checked the connections for bent or corroded pins. can anyone recommend a place to take the gauges to? i dont really wanna try to attempt this electrical problem on my own.
07-24-2003, 10:43 PM
#7
Gets Blown Daily
Bring it to your local electronics repair shop, and let them give you an estimate. Tell them not to do any work until they're sure they can fix it and discuss a price with you first.
Mods
-Shortstack headers
-Vortech RRFPR
-Remus full catback
-SMT6 EMS (Untuned)
07-25-2003, 12:42 PM
#8
BMW again.
Car: 1994 325is
thanks again guys, if this fails ill have to buy a new instrument unit, does anyone know how or If its tottally nessecary to decode it to make it work?
07-25-2003, 01:16 PM
#9
Gets Blown Daily
I've seen many clusters for sale cheap on ebay and at wrecking yards. i think the only downside to swapping a new one in is that it'll display the previous car's milage.
You'll need to get that reprogrammed by the dealer (which probably costs a lot  )
Mods
-Shortstack headers
-Vortech RRFPR
-Remus full catback
-SMT6 EMS (Untuned)
07-25-2003, 05:50 PM
#10
BMW again.
Car: 1994 325is
actually im not sure if you have to decode our displays, either way i can deal with lower mileage  , if i decide to go with an ebay cluster should i get some white faced gauges to keep the look of kilometers instead of miles? (i assume they will work exactly the same right? or is the US version set up different than ours? (if that last question doesnt make sense tell me) hahaha
