Old 07-22-2003, 01:05 AM   #1
LSD or not?
Does my e30 IS come with an LSD?
Old 07-22-2003, 01:40 AM   #2
johnoz
/OO=[][]=OO\
johnoz's Avatar
Yes. 325is is LSD (unless they replaced it for some reason)
http://bimmerforums.com/forum/showth...276#post355276
johnoz is offline   Reply With Quote
Old 07-22-2003, 02:09 AM   #3
cool! Thanx!
Old 07-22-2003, 03:01 AM   #4
Jon@Bimmersport
Jon@Bimmersport's Avatar
i need an LSD...so i can tear it up!! lol
Old 07-26-2003, 04:38 AM   #5
M3_MadBimmer
Send a message via AIM to M3_MadBimmer
what the hell is an LSD?
Luke
M3_MadBimmer is offline   Reply With Quote
Old 07-26-2003, 11:12 AM   #6
msifashion
It's a really ****ed up drug!!!
msifashion is offline   Reply With Quote
Old 07-26-2003, 11:49 AM   #7
M50E30
www.bmwclub.ca
M50E30's Avatar
Limited Slip Differential
Old 07-30-2003, 06:39 AM   #8
PrinceE30
Send a message via AIM to PrinceE30
Just jack up your car and look at the small tag on the diff. Should have a SD on it if it's a LSD...
-Prince
PrinceE30 is offline   Reply With Quote
Old 08-07-2003, 04:35 AM   #9
BoBimmer
BoBimmer's Avatar
How do I find out what ratio diff is in my car!??
MACHO MACHO MAN!! I WANT TO BE A MACHO MAN!! If I ever get this M50/B32 in maybe I will finally be a macho man!!
1991 325i(s) MINT!
Automatic (soon to be manual)
2.5L M20 (3.2L M50 ON ITS WAY!! '99 with 28K Miles!)
Bright Red
Stock body (soon to have Reiger E46 kit maybe M-Tech II?)
18" VoXX WHEELS
Stock suspension(OBX COILOVERS and tokico illuminas)
Remus exhaust (headers soon?)
Homemade intake
Indiglo gauges
stock BLAH brown interior leather (soon to have black vaders and all new black interior
Awesome system 2 12" JL W7's JL1000 amp JL 500.4 running 6x9 rear bostons and 61/2 front bostons!
2002 f350 Crew Cab Dually!
AIRBAGS ARE ON NOW!! Rollin' lower than Low_BMW scrapin' up the streets of DFW!! Tucking 22's almost to the center caps!!
2000 Jeep Wrangler TJ
Just got done adding a 6" lift 20" wheels with offroad Nitto tires! It is fun to take out on a sunday afternoon of rock climbing, or mudding when it rains alott!
BoBimmer is offline   Reply With Quote
Old 08-07-2003, 05:18 AM   #10
Slowered318
it should have a tag with the ratio on it.. maybe not because sometimes they rust off. then next time your at the shop on the hoist, slip under the car mark the half shaft at diff and the drive shaft. then count how many times it takes to turn the drive shaft for one single rotation of the tires. example 4 turns 3 3/4 turns, it will give you a close idea.
while your under there get someone to hold one tire while you turn the other, if it's hard to turn the LSD is working good. and both tires your rotate in the same direction if it's a true LSD.
Good luck
Old 08-07-2003, 06:23 AM   #11
SickFinga
SickFinga's Avatar
d-Lysergic Acid Diethylamide
Old 08-07-2003, 03:29 PM   #12
Jon@Bimmersport
lol
if u wanan check if u have LSD the fun way,...go in a huge empty flat parking lot...turn the wheel...press in the clutch, drop it into 1st, rev it high RPM and dump the clutch..if u spin around easily then u got LSD
Old 08-07-2003, 08:14 PM   #13
Slowered318
Originally posted by E46_lover
lol
Or just look at the rear tires.. if they are BOTH bald you got a LSD if the right side is bald you got an open diff.
Old 08-07-2003, 11:32 PM   #14
KennyTheGreat
KennyTheGreat's Avatar
Send a message via ICQ to KennyTheGreat
unfortunately only one tire was bald
KennyTheGreat is offline   Reply With Quote
Old 08-08-2003, 02:48 AM   #15
Sylak
325I 1989? they got a LSD ? because both tire in the same time.. Maybe just a Lock Diff..
Ohne dich zhl ich die Stunden ohne dich
Mit dir stehen die Sekunden
Lohnen nicht
Sylak is offline   Reply With Quote
