Old 07-20-2003, 02:40 AM   #1
sonic07
sonic07's Avatar
help on brake light circuit
this happens to me twice today,
check light came on, then on MID shows brake light circuit but then i shut off the car and turn it back on everything is clear and check everything is ok. it happened again a couple hours later and shut off the car and turn it back on everything is ok ....
i wonder if it has anything to do with the dinan chip that is installed there ?
also notice that the passenger back brake is squeeling like there is an animal is dying there .... and take a look there is about an inch patch of burn rust looking around the disk. hmmm time for the brake job perhaps ....
plz help anybody who knows this prob. thanks.
Pedal To The Metal
sonic07 is offline   Reply With Quote
Old 07-20-2003, 02:36 PM   #2
sonic07
sonic07's Avatar
anybody have a clue ...?
ok today i've decided to take apart that rear brake .... perhaps next week i'll ship it to the dealer at miss. bmw. if no solution.
Pedal To The Metal
Old 07-20-2003, 02:41 PM   #3
TiemenT
TiemenT's Avatar
Send a message via MSN to TiemenT
yess, maybe the dinan chip is causing it, but did you check the circuit ? maybe something broken or something...
Don't steel Pasta's SIG!
- Range Rover Hamann 5.0 Vogue V8 Sold for M5
- BMW ///M3 CSL
- E60 M5 on April 12th !
TiemenT is offline   Reply With Quote
Old 07-20-2003, 02:49 PM   #4
check a ground!
Old 07-20-2003, 03:28 PM   #5
R_JAY
Has the world for ransom
The brake light circuit actually has nothing to do with your chip or a burnt out bulb. It's a switch that is located under the dash (don't really know how to explain but trust me cause I had to change it too) and it touches the brake pedal when depressed. The only bad news is it's a bi*ch to get at. The part number is for it is 61-31-8-360-417 and it's only $21 bucks at the dealer.
Old 07-20-2003, 03:34 PM   #6
sonic07
sonic07's Avatar
thanks R_JAY ... that would make sense i'll work on it now ...
cuz i'm planning to go to dealer tomorrow to get some other stuffs too ...
Pedal To The Metal
Old 07-20-2003, 04:07 PM   #7
blkm3
Hi,
I exactly had the same problem but it only happended when I started the car and held my foot on the brake. What I did is changed the bulbs in the back lights or maybe you can just take them out clean them then put it back. It should solve the problem . mine did anyways . Also it could be that one of your bulbs has a bad filament . hope this helps.
if you dont want your chip i'll take it off you
blkm3 is offline   Reply With Quote
Old 07-20-2003, 04:08 PM   #8
R_JAY
This will tell exactly what to do to change it. http://www.logun.org/brake.htm
Old 07-20-2003, 05:02 PM   #9
Soldo
Soldo's Avatar
I had the EXACT same problem as well with my old RED n ORANGE lights, but then when i replaced them with the OEM clear lights, i noticed that there was ONE pin missing from one of the break lights which would cause it to tell the computer that!
Keven Soldo
Old 07-20-2003, 07:50 PM   #10
sonic07
sonic07's Avatar
thanks everyone .... for the recommendation .... i pulled out the switch and clean out the contacts and as well the light bulbs .... seems everything to work ok now. i even went to the extend pull out the wheel just check out that brake was squeeling clean out the pads they are brand new pads and took for a test run ...
Pedal To The Metal
