Old 07-05-2003, 03:36 AM   #1
Jon@MPerformance
'98 Turbo M3
Specs;
AA OBD2 Turbo Kit-Low boost 7.5psi and high boost 8.5psi. Turbo can do 10psi but with race fuel only. 328rwhp and 339ft.lbs torque at 9psi.
Jon@MPerformance is offline   Reply With Quote
Old 07-05-2003, 03:38 AM   #2
Jon@MPerformance
AA Lightweight Flywheel
AA High Performance Clutch Kit
AA Water Injection
Old 07-05-2003, 03:39 AM   #3
Jon@MPerformance
AA Level III Short Shifter
AA Rear Toe Bushings
AA Rear Shock Tower Brace
H&R Coilovers
UUC TME Bushings
SO3's
Old 07-05-2003, 05:21 AM   #4
Soldo
Soldo's Avatar
what color is that, TECHNO VIOLET?!car looks good either way, i love it how the intake is on the OPPOSITE side of the engine bay 'when its turbo'd!
Keven Soldo
Old 07-05-2003, 05:36 AM   #5
Jon@Bimmersport
Jon@Bimmersport's Avatar
why is max boost 10psi? turbo size or compression limiting your boost amount???
nice ride..
Old 07-05-2003, 05:45 AM   #6
Jon@MPerformance
Yes it is Techno Violet.
A few things that limits my boost... Siemens Engine Management System (OBD2), stock compression of 10.5:1, and fuel injectors.
Old 07-05-2003, 05:46 AM   #7
Jon@MPerformance
During the installation.
Old 07-05-2003, 05:46 AM   #8
Jon@MPerformance
The turbo
Old 07-05-2003, 05:47 AM   #9
Jon@MPerformance
the intercooler
Old 07-05-2003, 06:04 AM   #10
Jon@Bimmersport
you have a perf. chip in ur car? if you did the OBD1 conversion would you be able to run more boost?
Old 07-05-2003, 06:28 AM   #11
Jon@MPerformance
The turbo kit was installed by myself with lots of help from AA Tuning. The software was also dyno tuned by Karl Hugh at AA Tuning.
If I wanted to run more boost, I would have to lower the compression to 8.5:1 (AA Low Compression Head Gasket Kit), OBD1 Conversion, larger air mass sensor, larger fuel injectors, high flow fuel pump, straight pipe exhaust, and different spec wastegate/blow off valve to run about 15psi. This should yield to about 470hp and close to 500ft.lbs torque.
Old 07-05-2003, 02:08 PM   #12
Jon@Bimmersport
i c..i had a feeling about this..
i was getting a t26 turbo and manifold for cheap..so im picking it up (dont got a car yet either) and i know im getting 325is...but with this new job im starting, it is easy to make tons of money..so one member bought an M3 within 1 month of this job, so i figured in a year or 2 i can surely get one and afford it...
Now, if i were to slap the turbo on a 95 M3 would i have to send the tuning to karl? i dont want problems so i would want it done right...did you have to do all that because you had OBD2? what if i were to convert the OBD to OBD1 right when i got it, and then added the turbo?
the t26 maxes out at i think 15psi...i think 470hp and 500ft lbs of torque sounds good to me
Old 07-05-2003, 02:19 PM   #13
e30mpowerd
very awesome do u have a vidoe for it
e30mpowerd is offline   Reply With Quote
Old 07-05-2003, 02:49 PM   #14
mpower1226
mpower1226's Avatar
you are not starting WMA or whatever, are you jon?...
Old 07-05-2003, 02:56 PM   #15
Jon@Bimmersport
wats WMA?
