Old 06-29-2003, 08:19 PM   #1
Lil'Smoothie
Guest
Posts: n/a
Interior lights keep flickering
Ever since I installed my system my interior lights, like the clock light and gauge cluster lights keep flashing. Im running a 4 channel 320 watt and 2channel 300 watt amp and my deck off of one batery so im sure thats the problem
The alternator is brand new and puttin out the proper voltage
what should I do, upgrgade my alternator? If i get a second battery will I stil have to run it off my same alternator hence fixing nothing? Will my current alternator blow eventually?
Old 06-29-2003, 08:29 PM   #2
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
Flashing when the bass hits?
If you but in another bat it will have to run off your alt or it would just drain and that would be that.
You could get a cap
Stanceiseverything.com
Old 06-29-2003, 08:58 PM   #3
Gamite
Gamite's Avatar
I'm running a 1500 RMS amp, u shouldnt be experiencing bass lights. I only get it when I really push it. Then again, your battery is probably half the size of mine...
How old is the battery?
I agree with BMXer, get a cap, I need one too.
www.gamite.net
Old 06-29-2003, 09:05 PM   #4
Battery has nothing to do with it.
The alternators on E30's are notoriously weak. I know the common 325 upgrade is the 535 alt, but I have no idea for the S14. My interior lights flicker 24/7 even with everything off.
Old 06-30-2003, 12:21 AM   #5
Lil'Smoothie
Guest
Posts: n/a
so if I get the cap what will happen? Will I be good to go?
I was so embarrased last nite, I had a chick in my car and she thought it was supposed to flash like that, I guess thats what the ricers will be doing soon enuff
Old 06-30-2003, 01:34 AM   #6
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
If you get a cap it should stablize it. But I hear its a "band-aid" fix.
My lights dim.
Old 06-30-2003, 02:03 AM   #7
windsor318is
Nitrous Junkie!
windsor318is's Avatar
part of the problem has to be your battery, i noticed my lights dont dim as much know that i have a optima yellow top battery. a good battery and a cap should do it, caps arent cheap though,
