Old 05-28-2003, 02:28 AM   #1
MontrealR
Tire/Wheel Sizing
Hi,
Just wondering, for an E36 (non-M3); will a 235/40/17 tire fit on a 17x7.5 wheel?
What is the usual setup for tires for an upgrade to 17s?
Thanks.
MontrealR is offline   Reply With Quote
Old 05-28-2003, 06:28 AM   #2
MP328
Krv Svoju Za Bosnu Moju
MP328's Avatar
Send a message via MSN to MP328
the tires will fit without problems. unless the wheel has a strange offset it should not rub.
and the usual setup might be 225/45/17 since the overall diameter is a bit closer to the OEM overall diameter and the speedo isnt off by much.
MP328 is offline   Reply With Quote
Old 06-01-2003, 04:07 PM   #3
Mitch555
Retired MaXmember!
Mitch555's Avatar
Re: Tire/Wheel Sizing
Originally posted by MontrealR
Hi,
Thanks.
Whatz up MontealR?
Yeap, that will fit with no problem.
Mitch555 is offline   Reply With Quote
Old 06-02-2003, 06:53 PM   #4
MontrealR
18s
Hey Guys,
I've decided to go with 18s. I found some rims I like...however....they are 18x8, with a 35mm offset.
I called Tirerack and the person said I might need fender rolling.
Does anyone know if this offset is a good fit or not for an E36?
Thanks.
Old 06-02-2003, 07:01 PM   #5
Mitch555
Retired MaXmember!
Mitch555's Avatar
Re: 18s
Hey Guys,
Thanks.
First...... Is your car lowered? What suspension do you have?
Old 06-02-2003, 07:18 PM   #6
MontrealR
Suspension
Mitch,
Just ordered some Eibach Prokits for my car...so yes, it is lowered 1.5" front, 1.0" rear.
I talked to one person at TireRack who said that 35mm wouldn't be the best bet cuz I might need fender rolling.
AND then...
another Ebay seller that said it was only 5mm difference which won't really much of a difference.
Getting mixed opinions from different sides.
