Old 07-22-2014, 05:20 PM   #1
South
Tail light wiring
The car is a 95 325i, but has the euro clear taillights put on by P.O
The problem I only now noticed while changing a bulb is that only the inner tail lights light up when I press the brake, not the outer larger section.
Some sort of wiring mix up? any diagram? also whats the method of removing the wiring pins out of the connector box?
Nvm found the fix:http://www.bmconversions.co.uk/commo...ion_manual.pdf
