Old 07-07-2014, 11:04 PM   #1
BMW1
Fan Clutch Wrench set
Where I can find tool fan clutch wrench set in GTA?
I don't want order online from usa.
BMW1 is offline   Reply With Quote
Old 07-08-2014, 12:20 AM   #2
blk3
blk3's Avatar
Snap on, Matco, Mac usually have them on the truck
Old 07-08-2014, 02:01 AM   #3
rmanaudio
You don't need the tool. Get a 32mm and wack it really hard with a hammer a few times. I've never needed the tool. The belt tension has enough tention to hold for a quick hard wack to losen the fan clutch.
rmanaudio is offline   Reply With Quote
Old 07-08-2014, 08:42 AM   #4
Ceeker
the 32mm wrench is to thick to wedge in depending on the model you have whether earlier or later. What I did was I machined/planed a 32mm wrench down
to make it thin enough to fit. However you will still need something to hold the water pump pulley. I used a small wodden block or pry bar and wedge this between the pulleys to hold it from spinning while tapping the wrench. You may or may not get away with the pulley NOT turning. But if it does..no amount of hard whacking with the hammer is gonna remove it.
the other thing you can do is go to Sheridan Mall in Toronto. (Jane st/Wilson ave) there is a tool guy downstairs who has all kinds of stuff. He should carry that for the M20 engine. it comes as a set. but I think it's around 100.00
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 07-08-2014, 09:26 AM   #5
Ziploc
Look up the part number on Pelican and call the dealer. 30$ and it will be there next day.
Ziploc is offline   Reply With Quote
Old 07-08-2014, 10:11 AM   #6
TSI
Reverse Gear Member
Princess auto has the 32mm wrench thin enough for this. $20
TSI is offline   Reply With Quote
Old 07-08-2014, 10:12 AM   #7
BMW1
I mean fan clutch wrench holder and I don't have problem find 32mm wrench
Old 07-08-2014, 10:13 AM   #8
BMW1
Princess auto disconnect wrench holder
Old 07-08-2014, 12:22 PM   #9
325isdan
You just need to use a thin screw driver and thread it between two bolts to hold the fan in place
Sent from my C5306 using Tapatalk
325isdan is offline   Reply With Quote
Old 07-08-2014, 12:38 PM   #10
BMW1
Okay I will try it. I need change OFHG.
Old 07-08-2014, 03:21 PM   #11
gruppusol
make a tool yourself:
- buy a piece of 1.5" flatbar
- drill a hole a little larger than the bolt on the pulley
- contour the edge of the flatbar that will come into contact with central part of the pulley
- you could drill another hole on the flatbar to line up with another bolt for a more secure hold
mine works awesome!
'14 Subaru WRX STi Satin White Pearl hatch
'98 e36 M3 Techno Violet coupe
'00 e39 M5 Avus Blau - SOLD
'97 e36 M3 Cosmos Black sedan - R.I.P.
gruppusol is offline   Reply With Quote
Old 07-08-2014, 09:40 PM   #12
toy4to
I have the fan clutch wrench set if you'd like to rent them. Please PM me if interested..
toy4to is offline   Reply With Quote
Old 07-09-2014, 07:22 PM   #13
estoguy
This.
I have an E30 and I found that the 32mm wrench from Princess Auto fit perfectly. I had no problem removing it by hand. Remember, its a reverse thread, so it doesn't need to be super tight to begin with.
Another wrench that fits well is the UltraPro 32mm, but its a little more expensive.
1986 325 ~Elsa~
Alpenweiss
Need a photographer, come visit my site: http://estoguy.wix.com/unique-perspectives
"The future is uncertain and the end is always near."
estoguy is offline   Reply With Quote
Old 07-09-2014, 07:43 PM   #14
BMW1
Alright. I found one and I will get this week. Thank for everyone input.
Old 10-04-2014, 12:55 PM   #15
G.M.I
If you have to whack it with a hammer it was installed to tightly. Its reverse thread so that there's no chance of it coming loose during operation.
G.M.I is offline   Reply With Quote
