Old 07-06-2014, 02:02 PM   #1
andylourenco
2005 BMW E46 M3 clicking sound problems
my cars making a loud clicking sound from the engine don't know what it is mechanic says i possible need a new engine because the sound is coming from the bottom end. any help would be appreciated. engine has 96,000 kms. heres a video i found on youtube sound very similar probably a little louder. thanks
https://www.youtube.com/watch?v=OfDs8zQ2BZo
andylourenco is offline   Reply With Quote
Old 07-07-2014, 01:18 AM   #2
jabela
Have you done proper valve adjustments recently?
A vid of your car would help.
www.maisonapothecare.ca
Old 07-07-2014, 09:20 AM   #3
rmanaudio
LOL...new engine? Really? Take it to a real BMW mechanic and get a second opinion.
You have pretty low kms to have anything major wrong with it. Unless maybe the ROD bearing recall was not done (if your car is 2003 or older).
Could need a valve adjustment like jabela said. Or could be something simpler (pulley related, pump related).
The video sounds like knocking but it could be just knock sensor is not working and timing is retarded or advanced. A BMW mechanic would be able to give you a better idea. Saying you need a new S54 motor is just crazy. The engine is the most expensive thing on e46 M3.
rmanaudio is offline   Reply With Quote
Old 07-07-2014, 02:10 PM   #4
andylourenco
I got a valve adjustment still same noise there going to drop the oil pan to check things out.
Old 07-08-2014, 11:17 AM   #5
rmanaudio
Do a compression test if you can also. Let us know what you find.
Old 07-08-2014, 12:19 PM   #6
nx2000
It could be loose hub bolts on the cam. My car sounded like that until the bolts were tightened up. But if your mechanic said it's coming from the bottom end, it could be the bearings.
nx2000 is offline   Reply With Quote
Old 07-08-2014, 01:40 PM   #7
andylourenco
Finding fine metal shavings in oil
Old 07-08-2014, 04:05 PM   #8
rmanaudio
I would send your oil to get it analyzed. Find out what your Lead ppm is. If it is high you have eaten away at your rod bearings which will lead to high iron, copper, tin, etc.
Hard to image rod bearings with such low kms unless you track or beat the crap out of your S54 engine.
Old 07-10-2014, 05:16 PM   #9
twboy1999
if is e46 m3, iam sorry to tell you, most likely your vano tab has broken off or vanos bolts broken off
this is serious matter, you should get it fix asap
finger cross is not vanos tab
1997 honda accord
twboy1999 is offline   Reply With Quote
Old 07-12-2014, 08:29 AM   #10
Mike_G
any updates?
Mike_G is offline   Reply With Quote
Old 07-12-2014, 09:47 AM   #11
andylourenco
rod bearings needed to be replaced
Old 07-13-2014, 03:13 PM   #12
twboy1999
How much is, that gonna cost
1997 honda accord
Old 07-13-2014, 06:37 PM   #13
2bmwguy
winning
2bmwguy's Avatar
Same thing happened to me we thought if was the rod bearings replaced them ..then we started it up and the same knock noise was there..we found out it was the piston pin on #6
But...The bearing on #6 cly was really bad too. I end up buying another block with 70k on it after all that.!!. 4k later.
k&n / catless / evolve tuned / Michelin 305 cups.
2bmwguy is offline   Reply With Quote
Old 07-14-2014, 10:30 AM   #14
rmanaudio
Where you come up with this stuff? Exhaust Hub tab breaking off will not make that noise. If the tabs break, you might get codes or your engine will be dead (if tabs end up in chain and causing damage to timing). Most of the time you wont even know till you open it up or drop the pan.
The noise he has is piston movement related. So it could be rod bearings or piston related.
Old 07-14-2014, 11:29 AM   #15
ac_2007
Cruising in Top Gear
ac_2007's Avatar
Welcome back!
How was your vacation?
