Old 06-24-2014, 09:58 PM   #1
bimmere30
e30 running rich
what should i do? adjust the afm? btw i have a rough idle ... and so far i installed new spark plugs air filter and fuel filter already, and wires are only 30,000kms broken into.
bimmere30 is offline   Reply With Quote
Old 06-25-2014, 06:47 AM   #2
325isdan
How rich are you running?
325isdan is offline   Reply With Quote
Old 06-25-2014, 08:21 AM   #3
Ceeker
Do not mess with those settings...they are set by factory unless someone else had already tampered with it. You mess with that and you may not be able to get it back to normal.
are you absolutely sure you have the plug wires on correctly. check again at the motor and dist block.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 06-25-2014, 09:48 AM   #4
cirrusblau
Is the FPR working properly? What about the O2 sensor?
Old 06-25-2014, 04:21 PM   #5
bimmere30
i installed a new frp, i havent installed the o2
Old 06-25-2014, 04:24 PM   #6
bimmere30
i dropped my afm several times on grass maybe its retarded now
Old 06-25-2014, 04:59 PM   #7
Ceeker
maybe on concrete but grass shouldn't make a diff.
Old 06-25-2014, 05:16 PM   #8
cirrusblau
Are all your connections good? If the car gets stuck in open loop control, it will default to be very rich, but I think it would also throw a code if something like the AFM wasn't fully connected.
Are your temp sensors working properly?
Old 06-25-2014, 06:09 PM   #9
bimmere30
Coolant temp sensor looks old, yeah the connections are good I did the stomp test and got a 1215 code, so I checked the connections and they are good, but still I'm running rich and have rough idle
Old 06-25-2014, 06:18 PM   #10
DIY
Permanently Dirty
DIY's Avatar
I bet its your o2... But as already asked, how rich are you running? Irratic idle could be a vacuum leak... Clean your icv?
Old 06-25-2014, 06:19 PM   #11
Ceeker
well, it looks like its gonna be process of elimination. start swapping out parts. remember, certain parts are hard to come by... disconnect the AFM and see how the car runs.
some of things you can start checking:
air intake leaks
fuel injectors clogged or not opening
fuel pressure to low
air flow sensor flap binding
coolant temp sensor faulty or faulty wiring
throttle switch incorrectly adjusted or faulty
idle mixture incorrectly adjusted
idle speed control system faulty
incorrect ignition timing
poor fuel quality- water in fuel
cold start system operating all the time
faulty L-Jetronic or Motronic control unit (DME)
Old 06-26-2014, 12:05 AM   #12
Slowered318
Seriously (and because I've been told this many times) your best solution is simple... two words.
1. Motor
2. Swap
Old 06-26-2014, 12:11 AM   #13
Ceeker
1. Motor
2. Swap
some take longer to get around to it.
Old 06-26-2014, 04:00 AM   #14
Slowered318
I had it running pretty good last year, the BMW gods shone some light on me. This summer is ticking, rattles and a strange loss of HP. 13 years and a couple thousand dollars has taught me the M42 is relentless with issues.
Old 06-26-2014, 07:00 AM   #15
325isdan
The M42 is a great motor. My E36 has 360K when I gave it to my brother.
