Old 06-23-2014, 04:48 PM   #1
bimmere30
Stomp test video
here is video:
http://s186.photobucket.com/user/Swi...30007.mp4.html
bimmere30 is offline   Reply With Quote
Old 06-23-2014, 05:50 PM   #2
325isdan
Are you asking what the flashes represent? If so just google check engine codes.
Also FYI, once it goes through its cycle do the 5 stomps again. It doesn't always show all the codes.
325isdan is offline   Reply With Quote
Old 06-23-2014, 06:09 PM   #3
bimmere30
The code is 1215
1215 - Indicates problem relating to Air / Mass Flow Meter - AFM or MAF depending on your e30 model. Causes could be cable wire damage, short circuit in the unit, or air / vacuum leak (check air intake hose - big L-shaped one
The big L shape at the end has a crack so I had to use electric tape and was working before, but now it's worst, what part number is this?
