Old 06-22-2014, 04:52 PM   #1
bimmere30
Video of Car idling problem
I changed the fpr, and installed a new air hose to icv this is what I get:
I checked all vaccum hose they are connected, spark plugs are all carbon fouled
and I have a check engine light that goes away and comes back on. what could be the problem?
Car engine shakes when idling here is the video:
http://s186.photobucket.com/user/Swi...20004.mp4.html
bimmere30 is offline   Reply With Quote
Old 06-22-2014, 09:07 PM   #2
Ceeker
u really should take your car to someone who knows how to work on them.
check the seal on the oil cap and make sure the dip stick is all the way in.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 06-22-2014, 10:18 PM   #3
InfiniteDice
14 Years with the E30
InfiniteDice's Avatar
Check your engine mounts.. that's a lot of shake. I'm no expert on the 4cyls. The plugs should be beige to white, if they are black or bridged with oil then you have a serious oil return pressure issue or something. I'd agree with Creeker and have someone who is familiar with that engine have a look at it.
Old 06-23-2014, 12:35 AM   #4
El Gato Liso
El Gato Liso's Avatar
Firing order correct?
R.I.P. E30
Old 06-23-2014, 07:05 AM   #5
bimmere30
Yea it's correct
Old 06-23-2014, 08:33 AM   #6
You said the check engine light comes on... do the stomp test and tell us what the code is.
Old 06-23-2014, 08:48 AM   #7
Ceeker
^^ to do the stomp test. turn the ign to the on position where the dash lights come on. Stomp once quickly on the gas pedal - release wait a sec then stomp another 5 times repeatedly and wait( opps correction 5 times total -thx). you may have to do this a few times to get the timing right before the check engine flashes to give you a sequential code.
just count how many times it flashes for each digit - remember it's 4 digit code.
Old 06-23-2014, 09:07 AM   #8
Originally Posted by Ceeker View Post
^^ to do the stomp test. turn the ign to the on position where the dash lights come on. Stomp once quickly on the gas pedal - release wait a sec then stomp another 5 times repeatedly and wait. you may have to do this a few times to get the timing right before the check engine flashes to give you a sequential code.
It's just 5 times, not 6
http://www.unofficialbmw.com/repair_faqs/motronic.html
Old 06-23-2014, 09:36 AM   #9
Ceeker
my bad..
Old 06-23-2014, 10:25 AM   #10
Nguyen_E30
0011 0001 1000
did you check your oil level?
Nguyen_E30 is offline   Reply With Quote
Old 06-23-2014, 03:59 PM   #11
bimmere30
Oil level is good
