Old 06-07-2014, 02:58 PM   #1
Ceeker
drivers door lock e46 320 sedan
So I just replaced the drivers lock cylinder and it works fine with the key in. The door locks are sync'd. they lock and unlock. However, the drivers side door lock in the lock position allows me to still open it.
So; what could be the issue here?
Key fobs also don't work.
any help would be appreciated. thx.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 06-08-2014, 01:06 AM   #2
jabela
Are you sure you properly reconnected everything? Or didn't break anything?
www.maisonapothecare.ca
Old 06-08-2014, 07:14 AM   #3
Ceeker
I hadn't touched anything inside the door. All I did was replace the lock cylinder because the key was just spinning.
Old 06-08-2014, 12:34 PM   #4
jabela
Sounds like you door lock module is faulty. Part #1. I had to replace mine recently. Different failure mode though.
http://realoem.com/bmw/showparts.do?...=41&fg=40&hl=6
Old 06-08-2014, 04:22 PM   #5
Ceeker
That has been my suspicion. Although the plunger is working something inside it isn't connected to it. So the lock doesn't do anything. I got a handle on one that I can grab later. I just was hoping this wasn't it..lol wanted to avoid the job..haha thanks for your help.
