Old 06-18-2014, 09:40 PM   #16
rmanaudio
Then that is not consumption. If you are not burning it, then it can be fixed. BMW engines burn oil. Some more than others. There is a reason why BMW gives you a bottle to carry in the trunk for when the yellow oil light comes on.
rmanaudio is offline   Reply With Quote
Old 07-02-2014, 10:34 PM   #17
6appeal
6appeal's Avatar
I actually burn about a quart every 1000-1200kms. That sounds very excessive compared to what you guys are reporting. My car did have an "oil bomb" a few winters ago and I replaced the CCV with the updated version, replaced spark plugs, replaced VCG. I had Rocco do my VANOS seals with the Beisan kit as well and I change my oil every 5-7500kms with BMW 5W-30 Synthetic. I don't have any leaks that can be the cause of this much oil loss. Any thoughts?
6appeal is offline   Reply With Quote
Old 07-02-2014, 10:46 PM   #18
jabela
No leak at oil filter housing?
Valve stem seals are common, but too much of a pain to replace.
You could use a heavier oil like Shell Rotella T 5w40 synthetic. Works for me and got rid of lifter ticking too.
www.maisonapothecare.ca
Old 07-07-2014, 09:27 AM   #19
rmanaudio
Stop worrying about it and start driving it. Life is too short to worry about stuff like this. Your burning rate is still within BMW specs. Just make sure you always check your oil. Do not run the engine when oil is low (yellow oil light is on), you will blow the bottom end of your engine off.
