Welcome to!
Old 06-04-2014, 10:12 AM   #1
oil dipstick smells like gasoline
what should i do?
bimmere30 is offline   Reply With Quote
Old 06-04-2014, 11:41 AM   #2
Unless your oil level appears to be rising... in which case you likely have an injector stuck open... then just drive it.
There's always going to be a certain amount of blow by (that's why motors have crank case vents) that'll mix in with the oil and give it a hint of gasoline odour.
Old 06-04-2014, 11:42 AM   #3
yes! as's called leak down!! common with relatively higher mileage cars. :-)
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 06-08-2014, 08:36 PM   #4
i would change the oil too if it's bad enough or less u getting lack of lube
Old 06-08-2014, 08:44 PM   #5
Ya, change the oil and drive it more
