Old 06-01-2014, 09:28 PM   #1
partner103
Shops you have experience with (powdercoating)
So search didn't come up anything on the forums. I have a spare M42 valve cover, and upper manifold I want powder-coated.
Any shops in the GTA you'd recommend, that do this properly?
partner103 is offline   Reply With Quote
Old 06-01-2014, 10:13 PM   #2
I can tell you who to stay AWAY from; Metal Coaters in Bramption, very large and busy shop, but the work they did for me was horrible. Top that with poor customer service, and it's sure a place i'll never visit again! Check out my other thread about them.
Old 06-02-2014, 01:14 AM   #3
yuiou
Driver
yuiou's Avatar
Give Mike at Brightside Coatings a call
yuiou is offline   Reply With Quote
Old 06-02-2014, 08:19 AM   #4
E30 Girl
E30 Girl's Avatar
Send a message via MSN to E30 Girl
Best place with reasonable prices is a place called Fireball Coatings. Not sure where you're located but these guys are in Erin but it is well worth the drive.
Speak to Mark he is the owner.
E30 Girl is offline   Reply With Quote
Old 06-02-2014, 10:16 AM   #5
Slowered318
I had a good experience at Quy's Coating in Brampton. They have done a few jobs for me and I plan to use them again.
With the M42 valve cover I highly recommend you remove the metal heat shield before powder coating. You can easily drill and rivet it back on after. Sand and grit gets trapped behind it and the heat from the bake WILL warp the plate.
Went with "wrinkle" satin black.
Old 06-02-2014, 03:18 PM   #6
Robb
EX E30 M3 Owner
Robb's Avatar
I had some vintage REDLINE FORKLIFTER BMX bars done there. Cheap.
Robb is offline   Reply With Quote
Old 06-03-2014, 05:17 PM   #7
partner103
thanks guys, I'll try the ones recommended, and close to me.
Old 06-15-2014, 10:24 PM   #8
Ceeker
I have use Bright side numerous times. they do thorough work and are reasonably priced. They are now located in Toronto on O;conner Drive. give them a call. Ask for Mike - owner.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
