Old 05-30-2014, 01:58 PM   #1
rmanaudio
RTAB tool
Look to borrow for a day or 2, correct tool to take out and install RTAB in e46.
I don't think Autozone or CT has the correct tool, just a puller.
rmanaudio is offline   Reply With Quote
Old 06-01-2014, 12:53 PM   #2
mr ilia
Yes, they do have a kit, but it only works to press bushing in, to take old bushong out you will have to improvise. I just drilled out the old one and used ct rental kit topress one it. You need ball joint master kit for it.
2004 BMW 325i, sedan, 5spd.
Old 06-02-2014, 09:38 AM   #3
cirrusblau
Can't speak for the E46 directly, but for RTABs on the E30, I used threaded rod, a pipe cap with a hole drilled for the treaded rod and a short section of pipe.
FWD bearing puller at Partsource has a good selection of hardware that helps too, but wasn't long enough to handle the RTABs on the E30.
Old 06-02-2014, 12:09 PM   #4
rmanaudio
Thanks guys. I will pickup the ball joint master kit at autozone.
A lot of people trying to make money off of renting tools to members here. I thought we are here to help each other!?!?
