Old 04-13-2014, 06:12 PM   #1
<3MyE36
-Richy Nevaless-
<3MyE36's Avatar
Anybody else ever experience this?
Hey maX members!, so recently I ordered a pair of OEM replacement rear coil springs & rear shocks/struts for my E36 I gave the parts store the part numbers, and even compared the new to old in size, but once I installed them I realized that my car is way lower than the old ones I had, I literally can barely fit a finger in between my wheels and wheel arch (it's rubbing like crazy) anyone ever come across a problem like this or know the cause for it? Thanks.
-Rich
<3MyE36 is offline   Reply With Quote
Old 04-14-2014, 07:52 PM   #2
<3MyE36
-Richy Nevaless-
<3MyE36's Avatar
Anybody?
Old 04-14-2014, 08:22 PM   #3
TSI
Reverse Gear Member
Kind of hard to say without knowing part numbers, car model, brand, etc...
TSI is online now   Reply With Quote
Old 04-14-2014, 08:55 PM   #4
<3MyE36
-Richy Nevaless-
<3MyE36's Avatar
The brand of the coil springs are called "Suplex" And the shocks are Monroe I don't have the part numbers any more, I threw out the boxes, (this is meant to be a temporary set up until I buy coilovers) and the car is a 1993 320i, sorry I can't provide more information.
Old 04-14-2014, 09:47 PM   #5
jabela
OK, well you might have confused everyone by saying that they are OEM replacements.
It might be more clear to say that they are aftermarket replacements for stock parts.
Most likely the parts store gave you the wrong parts. I've never heard of anyone using those brands on a BMW, but I'm not the most knowledgeable member here.
You should be able to look up the correct parts in those companies' catalogs.
www.maisonapothecare.ca
jabela is online now   Reply With Quote
Old 04-15-2014, 06:27 AM   #6
DET1990
shoulda went junkyard route
DET1990 is offline   Reply With Quote
Old 04-15-2014, 08:48 PM   #7
windwagen
windwagen's Avatar
Slam the front to make it match
E39 M5 - for Sunny Days
Old 04-16-2014, 12:06 PM   #8
<3MyE36
-Richy Nevaless-
<3MyE36's Avatar
Haha I was thinking exactly that, seeing as it's too late to return the parts.
Old 04-17-2014, 12:56 PM   #9
bart325is
IH8BART
Are there isolators you could install to raise it up a bit? Or just put the old ones back on?
e30 less
bart325is is offline   Reply With Quote
Old 04-17-2014, 01:16 PM   #10
<3MyE36
-Richy Nevaless-
<3MyE36's Avatar
I used the new ones, figured I might as well change them while doing the springs and shocks.
Tags
coil springs, e36, rear, rubbing, strut
