Old 04-06-2014, 05:04 PM   #1
BADRAT
badratart.com
BADRAT's Avatar
Lightbulb Hood Release Cable DIY Help
hey guys,
I was having trouble with my hood staying down, upon further investigation i noticed my hood release cable has started to rust. as preventative maintenance i want to get this replaced before the cable has the opportunity to snap (that could get ugly ). I already have the two bowden cables (shown in green) - one between the two latches (latches shown in red) and the other that runs up the drivers side of the engine bay.
I was hoping that the replacement would be simple, but it isn't looking that way. I'm actually not too sure how to go about doing this. the middle cable seems to run under the front bay support, with tons of intake plastic in the way and between the radiator. has anyone done this before? any advice?
id hate to remove the bumper and all the front intake components, or even the radiator to find out there was a simpler way.
thanks!
File Type: jpg Screen-Shot-2014-04-06-at-4.52.38-PM.jpg (148.2 KB, 58 views)
BADRAT is offline   Reply With Quote
Old 04-06-2014, 06:58 PM   #2
lube the shit out of the latches..9/10 it isn't the cable the latches start to seize and the cables start stretching resulting in cable failure. Spray lube and move the handle back and forth until you feel no resistance on the cables.
Old 04-06-2014, 07:02 PM   #3
BADRAT
badratart.com
BADRAT's Avatar
yeah I've cleaned them up quite a bit. though i can see the cable rusting, the nylon is cracked and bloated with it
Old 04-07-2014, 06:31 AM   #4
cheapthrills
http://forums.bimmerforums.com/forum...e-cable-breaks
Try the steps I listed there, and let me know if you still have questions. It's a pain, but you don't need to pull the bumper, just the intake ram air above the grille nostrils.
cheapthrills is offline   Reply With Quote
Old 04-07-2014, 07:40 PM   #5
BADRAT
badratart.com
BADRAT's Avatar
I'm almost 100% sure my car doesn't have those two screws shown in blue. if i did i would have attempted that (2000 323i problems?) would you say the wiggle room came from removing the fender bolts?
Old 04-08-2014, 07:29 AM   #6
cheapthrills
Looking at RealOEM, both our cars have the same part numbers listed for these parts: 51 71 8 211 467 for the plastic piece, and 51 71 7 111 691 for the radiator support, so I'm pretty sure you should have them.
Note that I didn't loosen the fenders, rather the bolts between the radiator support and the fenders. 3 of these 4 bolts can be seen in the picture you posted above.
You definitely have to bend the plastic guard to wrestle it out. I didn't break mine, but I wouldn't have cared if I did. I did not reinstall it.
Old 04-13-2014, 06:59 PM   #7
BADRAT
badratart.com
BADRAT's Avatar
Thank you very much cheapthrills. Tackled this beast today and was successfull!
The screws did exist and made quite a difference when removed. I also unbolted the radiator support and the two top nuts to the aux fan for more wiggle room. There was a ton of bending and flexing with the plastic, thankfully nothing broke. Be prepared for a struggle though, it's not easy.. major hand and forearm cramps!
As preventative maintenance I would recommend someone to do this if they ever replace their aux fan. The cables are fairly cheap and are easier to access if you are replacing your fan. I'm glad I finally did mine as the cables were VERY rusty and had an end piece snap off while replacing. Now everything is smooth and I don't have to worry every time I pop the hood
Sent from my Z10 using Tapatalk
Tags
bowden, e46, hood, hood cable, hood release
