Welcome to!
Old 01-31-2014, 04:11 AM   #1
Suddenly lost power
I don't seem to have the usual power anymore. Even when flooring it, it just gradually revs up in every gear (manual transmission) is picking up speed slowly but that power just isn't there. Feels like a 50 HP car now...
There are no engine lights or anything.
So any ideas what it can be? What can I check?
bimmer1 is offline   Reply With Quote
Old 01-31-2014, 07:39 AM   #2
Is the top end power still there? If VANOS isn't working properly, it takes away a lot of the low-mid range torque, but the high-rpm power is only slightly reduced. The engine is still smooth and not stuttering?
Get the codes pulled with a BMW-specific scanner before doing anything else.
cheapthrills is offline   Reply With Quote
Old 01-31-2014, 01:47 PM   #3
The engine is still smooth and not stuttering at all. There is a clear loss of power in the low-mid range...I'll check the higher range and let you know.
Is the VANOS known to fail?
Can having too much engine oil cause this? I topped up engine oil and didn't properly ensure it was at correct level.
The engine light is NOT on so I doubt there's any codes but I'll check anyway.
Old 01-31-2014, 02:00 PM   #4
afaik when the vanos fails it usually loses low end power, not top end, so could be vanos. also check:
fuel pressure
plugs (unlikely if not missing)
I run a canadian led kit & hid kit company, if you have any questions about led headlights or hid kits in canada or would like to check out our products please contact me here:
Old 02-14-2014, 09:33 PM   #5
You may need a clutch. Since you are in Mississauga, take it somewhere where it can get diagnosed properly. Techmax on Tomken Rd. and Meyerside does my work when it's over my head.
xlr8nbimbo is offline   Reply With Quote
