Old 04-02-2014, 11:36 PM   #151
Meh, I always just keep my car full at the track... don't have to worry about starvation then!
Old 04-10-2014, 02:15 PM   #152
I got some of the little bits and bobs for my throttle cables in the mail this week... all the way from the UK.
I should hopefully be able to finish up the throttle mechanism for the ITBs this weekend.
I'm also going to go with a dual vacuum manifold set-up, one for the brake booster and the other for the FPR and MAP sensor. Each throttle body has two barbs so I can run one line from each throttle body to each manifold.
Old 04-15-2014, 11:23 AM   #153
I like the execution of this tubular front end...
It's for a pretty dope 2jz E30 drift car...
http://onroaders.com/blog/1529/l-m-r...h-of-fresh-air
Old 04-15-2014, 01:10 PM   #154
Yamahammer
Warlock of the century
Yamahammer's Avatar
Now that, I like. The reservoir in the passenger side looks super clean.
Old 04-15-2014, 06:16 PM   #155
richie_s999
Originally Posted by aviator View Post
Another option might be to look into using a tank from an MB300E the W124 body had the tank behind the rear seat back... you'd loose a little trunk space but it could work... of course you'd have to re route some of the fuel lines... interesting that BMW would use a system that needs two fuel pumps to work correctly...
They did dual pumps to get the gas tank in a spit that would optimize weight distribution, as the tank is really 2 tanks you gotta get gas to go from one side to another. They must have done something right cause the e30 is the car that made the company what it is today.
Old 04-20-2014, 09:11 PM   #156
aviator
Makes sense... also added stability in the corners without all the fuel sloshing from side to side and the weight being low down... never said it was wrong just interesting... they could have devised a single pump with dual pick-ups I bet...
aviator is offline   Reply With Quote
Old 04-26-2014, 07:32 PM   #157
I made some adjustable sway bar links for the front sway bar last night after work.
I took the front shock assemblies off the car today so that I can shorten them another 3/4" just so that the shocks aren't riding so close to the bump stops and I'm going to weld on the brackets needed to run these "M3 style" adjustable links.
Old 04-26-2014, 08:27 PM   #158
^ You will like the way the car drives with that front sway bar setup. I love mine! Although fancy adjustable links would be the icing on the cake
Old 04-26-2014, 10:58 PM   #159
Yamahammer
Yamahammer's Avatar
Right on!
Just watch the misalignment angle on those rod ends. Make sure when you fab the tabs on the strut housings they wont be too far off plane.
Old 04-27-2014, 01:53 AM   #160
aviator
Those links look sweet...
Old 08-08-2014, 03:23 PM   #161
Yamahammer
Yamahammer's Avatar
So....
whats happening all??
Old 08-08-2014, 03:36 PM   #162
Old 08-08-2014, 03:51 PM   #163
Just passed my etest... legit this time! Yay me lol!
Old 08-08-2014, 03:56 PM   #164
Yamahammer
Yamahammer's Avatar
lmfao!
Congrats. You give hope to all that own e30's...
Old 08-08-2014, 07:59 PM   #165
I've passed the e-test in my E30 legit once... before I dropped in my new motor lol.
In all honesty though I probably could have passed it last year too if I had a legit cat rather than an $80 vibrant cat lol.
I'm going to try running a 3 wire harness directly to the MS this weekend to see if that'll fix my jumpy TPS signal.
