Old 01-11-2014, 09:09 PM   #1
Noxas
E46 headlights preface lift vs facelift.
Hi I was just curious if anyone knew if the two headlights were able to interchange? Is all that's required just a change in the lenses?
Thanks! Been hearing things so was just curious
Noxas is offline   Reply With Quote
Old 01-12-2014, 11:45 AM   #2
98bimmer
yes, you change swap the inner and outer lenses between 99-01 sedans, 2000-2003 coupe and 2002-2005 sedan headlights but you cant swap the lenses between 2004-2006 coupes
98bimmer is offline   Reply With Quote
Old 01-12-2014, 03:55 PM   #3
Noxas
Thanks although I'm still sort of confused. When you speak of lenses are you talking in regards to the clear plastic piece? What about the entire housing itself?
Old 01-12-2014, 03:57 PM   #4
98bimmer
The housings are the same, the inner and outer lenses are different but are interchangeable between headlights
Old 01-12-2014, 04:58 PM   #5
Noxas
So the outer lens... Would be the cover of the housing? And the inner is? Do you happen to have a part number? May help clarify things better.
Thanks again! Appreciate it
Old 01-12-2014, 05:01 PM   #6
98bimmer
Don't have the part numbers but where the bulbs go in is the housing. The outside lenses and the inner bezels transfer able, the bezels sit right behind the outside lense
Old 01-12-2014, 05:33 PM   #7
Noxas
Hmm so with that being said... Is using a preface lift xenon headlights a direct transfer into a face lifted e46? Are there any additional parts I will need? Or is it simply an adjustment of parts from the old headlights
Old 01-12-2014, 05:34 PM   #8
98bimmer
Simple swap, I would say take your headlight and ask the guy to swap it to show you and it's also plug and play, it's honestly the easiest swap you can do lol
