Old 01-05-2014, 08:58 PM   #1
Pongs318
2001 320 start n stall
HI just pick up a 2001 320 I got it to start but idles rough check code said temperature running cold or termostst code erase code now car, wont start start then stall right away like no spark,any idea pls thanks
Pongs318 is offline   Reply With Quote
Old 01-06-2014, 01:11 AM   #2
windwagen
windwagen's Avatar
Make sure there is gas in it.... Could the gauge be broken? Next... check for vacuum leaks - loose/broken hoses around the intake
Old 01-06-2014, 02:22 AM   #3
jabela
If not low on gas, likely it's a vacuum leak. Did you not test drive the car before buying?
www.maisonapothecare.ca
Old 01-06-2014, 07:44 AM   #4
Pongs318
suspect is cranksensor plugs are wet will get the sensor then dig a bit deeper thanks
Old 01-06-2014, 08:39 PM   #5
windwagen
windwagen's Avatar
are you 100% sure about the gas? My buddy went through this with his 540... runs perfect... then starts running rough.... then doesn't run at all.... gas gauge was bad.
Old 01-06-2014, 10:06 PM   #6
windwagen
windwagen's Avatar
Frozen gas line????
Old 01-06-2014, 10:55 PM   #7
SamE30e
SamE30e's Avatar
The thermostat controls fuel enrichment. If it is bad it will dump fuel like crazy on start up. Also, E46's have MAP thermostats, they are prone to failure and require replacement. Check the wiring connection to the thermostat it self, and check the temp sensor.
85 325 - Turbo M52B28.
Old 01-07-2014, 01:07 AM   #8
windwagen
windwagen's Avatar
If plugs are really wet from flooding, you may not have any compression. Gas washes oil off the cylinder walls. Check to see if the oil is too full or smells like gas.
Old 01-11-2014, 09:47 PM   #9
Pongs318
ok solve the problem gauge reads 1/4 tank so i put in more gas the it runs perfect pump i going i think thats why the other side of tank have gas while other side is empty thanks for the help guy will do the pump/filter/termostat and valve gasket now looking for side mirror cover does anybody have one laying around and lowering springs thanks
Old 01-11-2014, 10:06 PM   #10
windwagen
windwagen's Avatar
Please use a grammar checker... I'm not sure what you're saying...us it running?
