Old 12-18-2013, 09:47 AM   #1
aberg83
aberg83's Avatar
Brake Pressure Regulator Help
Trying to reach the pressure regulator to disconnect the main front to back brake hard line. For the life of me, I can't figure out how to get any tools in there to disconnect this fitting. It's too tight. Any tips?
aberg83 is offline   Reply With Quote
Old 12-18-2013, 03:58 PM   #2
Ceeker
you could get brake line crows feet wrenches or socket. you'll most likely need to attack that from underneath. DON'T try it with vise grips or any other or you could potentially strip it and then you're really mucked.
and if you can get some heat in there providing you aren't close to any fuel lines that would certainly help. But use extreme caution if there are.
not recommending it...just making sure you're clear on that. :-)
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 12-18-2013, 04:14 PM   #3
aberg83
aberg83's Avatar
One thought I had since the existing brake line will be replaced is to cut it and slide an 11mm box end over the line and remove the nut from the regulator below working from beneath the engine bay. I could do the same with the new line before securing the other end of it. I'm hoping since the connection is in the engine bay it won't be seized up with rust and should come loose fairly easily, unlike the connections at the rear. Thoughts?
Old 12-18-2013, 04:28 PM   #4
Ceeker
good luck with that..I've never tried it.. you'll most likely strip it with a 12 point. maybe a 6 point might work...if you're replacing the entire line..however, how are you going to turn the wrench in such a confined space? that's why a crows foot socket can get in their with an extension and rachett
Old 12-18-2013, 04:32 PM   #5
aberg83
aberg83's Avatar
Using a crowfoot socket and extension, would you not have to access it from above?
Old 12-18-2013, 05:43 PM   #6
Ceeker
you can try...sometimes you have to get creative to get parts off a car.
Old 12-19-2013, 04:08 PM   #7
aberg83
aberg83's Avatar
Decided to abandon it and instead cut the line under the car where I can reach it, flare a new connection. Been playing around with a Partsource bubble flare kit rental on a scrap line. Hard to know if I'm doing this right. How does this one look?
Old 12-19-2013, 04:32 PM   #8
Are you sure they gave you a bubble flare kit and not a double flare tool?
Bubble flare on left, double flare on right.
Old 12-19-2013, 04:52 PM   #9
aberg83
aberg83's Avatar
It's definitely a bubble flare kit. I think I didn't push enough of the line through the tool so the mushroom isn't as pronounced. I'll have to try some more to get the hang of it.
Old 12-20-2013, 10:15 AM   #10
Deetow
I guess it's too late to help you out now but I had to replace that exact brake line this summer. I managed to get small needle nose vice grips in there to hold the nut on the regulator and a small wrench to turn the brake line. Setting up took about 10 mins, but the connection broke free in one try.
Deetow is offline   Reply With Quote
Old 12-20-2013, 10:48 AM   #11
aberg83
aberg83's Avatar
Not too late. I haven't done anything yet. May yet try your suggestion.
Old 12-20-2013, 09:12 PM   #12
aberg83
aberg83's Avatar
Getting better!
Sent from my iPhone using Tapatalk
Old 03-04-2014, 05:55 AM   #13
cormier
cormier's Avatar
Nice flare! make sure you file down the inside nicely if there are any burrs in there
Old 03-05-2014, 07:48 AM   #14
ryanjv
ryanjv's Avatar
Send a message via MSN to ryanjv
Since i was replacing that long line that goes towards the back, i just cut it. Once it was in my hand, just use some wrenches to take the rest of the line out of the regulator. I don't if Princess auto has them, but i went to Harbor Freight and picked up a 10 piece crow foot wrench kit for $10
ryanjv is offline   Reply With Quote
