Old 12-09-2013, 11:11 PM   #1
jcr
Three Stage Intake Manifold
Just wondering if anyone has done the three stage intake manifold swap for their N52 engine? If so where did you get the part and who installed it?
jcr is offline   Reply With Quote
Old 12-20-2013, 02:15 AM   #2
Revision2
Revision2's Avatar
I know of at least 4 local (GTA) 328s that have done the swap. I believe all of them got it used through various junk yards / other members of another forum. I know 2 of them did the actual swap themselves while the other 2 went to Bimmersport to do it for them. Keep in mind that after doing the swap you will need an ECU tune as well in order to get the most out of the mod.
Revision2 is offline   Reply With Quote
Old 12-20-2013, 07:59 AM   #3
jcr
Hmm I have trying to find one used but not having much luck locating one or if I do no one can confirm the part number or send pictures of it.
Old 12-20-2013, 03:43 PM   #4
DIY
Permanently Dirty
DIY's Avatar
If you get doogee to reply he's done it
Old 12-20-2013, 05:19 PM   #5
Blades
Your opinion is to long
Blades's Avatar
I'm still waiting on some parts but I am doing it.
-=[ BL/\DES ]=-
Old 12-20-2013, 06:03 PM   #6
jcr
Where did you get the intake manifold from?
Old 12-21-2013, 01:08 AM   #7
Blades
Blades's Avatar
Not sure .. Mechanic picked it up for me
-=[ BL/\DES ]=-
Old 12-21-2013, 01:32 AM   #8
jcr
Just wondering how much did you pay for it and did it come with the valves?
Old 12-21-2013, 01:21 PM   #9
doogee
doogee's Avatar
Your best bet is finding someone with a core engine willing to part with the manifold. Otherwise, you're stuck buying it new along with the DISA valves.
I swapped it myself in under 2 hours. Pulling these things off is 10 times quicker and easier than the E36/E46. No more mess of wires and hoses underneath!
The wiring for the DISA valves is already on your current wiring harness too. The power gain is significant.
Dakar M3 Track Build Thread
Old 12-21-2013, 01:37 PM   #10
jcr
Yeah I can't seem to find any junk yard locally that will part it. Found some in the states but they can't confirm the part for me.
Old 02-13-2014, 12:14 AM   #11
doogee
doogee's Avatar
I may be able to source one for you.
Old 02-13-2014, 12:17 AM   #12
jcr
I have picked one up... maybe a little older because it only has one port for the vent hose when the 09 328i has two port... so I need to figure out how to plug one of the ports.
Which tune did you use and was it a local place?
Old 02-13-2014, 10:13 AM   #13
doogee
doogee's Avatar
Sweet! I'm going to get an Active Autowerke tune from Bimmersport this summer. I don't have anything yet.
Old 02-13-2014, 11:16 AM   #14
jcr
Yeah AA tune and there was one more I don't remember that people normally use. Trying to figure out the difference.
Actually this is what I picked up http://www.e90post.com/forums/showthread.php?p=15341701 so if you look at Post 13, I need to figure out how to plug it like that... either I need to know the dimensions of that hose or buy another hose.... parts in Canada cost so much more..
Old 03-16-2014, 12:26 AM   #15
E36Bimmer
I have seen a few for sale on ebay.
E36Bimmer is offline   Reply With Quote
