Old 12-01-2013, 06:49 PM   #1
90five
2 Questions About My Car.
I have a 1995 325is during the process of overhauling I've came across a few issues that I can't solve on my own and haven't been able to find any help online. First one is when I put my car in drive the rear lowers and the back passenger side lowers more then the drivers side. Due to my wheels and spacers my tire touches on that side. I'm aware I need my fenders rolled still but it would like the car to sit even. Any ideas? I want to switch to springs and not a full coilover kit could it just be a bad strut? Also is there a way to delete the auto rear drop when in drive?
My second problem is my drivers side front marker/turn signal doesn't stay on same with the tail light. I know the bulbs are good because I swapped them with the passengers side it's just the drivers side is dead any help with that would be great. Thanks in advance.
90five is offline   Reply With Quote
Old 12-02-2013, 07:03 AM   #2
E36is
'OldSchool..'
E36is's Avatar
I will take a stab at it.
question #1. first is the car stick or auto? my guess would be that the emergency brake is grabbing even though you have it off. I would pull off the rotors and inspect/lube/adjust to make sure when it is disengaged that is not grabbing.
question #2. wire connection is broken you will have to do a 12v test at connection and trace.
Old 12-02-2013, 10:01 AM   #3
90five
Car is an auto. I will check those options out today. The lights worked fine up till about 4 days ago
Old 12-02-2013, 12:31 PM   #4
SiR
Vtec just kicked in
the battery is in the trunk on the passenger side.
-||Old Crayons||-
Old 12-02-2013, 12:34 PM   #5
90five
The batt would sink it down that much though?
Old 12-02-2013, 08:19 PM   #6
Dinanstu
Your shock is done on that side...
