Old 11-26-2013, 09:06 PM   #1
st4chu
st4chu's Avatar
39 528i problem
Ok so today i was driving back from work when i felt like drop of rps in my car check engine was on bc of o2 sensor but it didnt feel right so down the road i was driving and yet again it happened it dropped rps and then had no power when i was changing gears it looked like it will die on me and then it kicked in and went. so i came home scaned and there u go p0340 cps now the question is if i have injector tapping making noise its bc of that cpa or it might be timing that it skipped if it would skipped would i get missfire codes as well or not rly. what brand of cps should i get i duno about aftermarket ones but i know they are shitty and i dont know who makes oem ones thnx for sugestions
st4chu is offline   Reply With Quote
Old 11-26-2013, 09:16 PM   #2
why do you think your cel was caused by an o2 sensor if you threw a cam position sensor code.
get an OEM one from the dealer.
O2 sensors will never cause sporadic idle (if they do, unplug them, car will run fine without them)
Old 11-26-2013, 09:20 PM   #3
st4chu
st4chu's Avatar
I had the cel on bc off chipmunk was hungry and bit the cable off o2 sensor so as soon i felt droping rps i scaned it and there was 2 codes one for o2 and second one for cps which is p0340 if the timing skips could it triger that p0340 code or its just a bad cps i have hard time to start my car and like tiking noise from bank 1 injectors ig that helps
Old 11-29-2013, 01:17 AM   #4
st4chu
st4chu's Avatar
nvm found reason insolation on cable pilled off and it shorted intake cam sensor
