Old 11-11-2013, 11:05 AM   #1
alaadeen
Engine Temperature for E90
Hi folks,
This may be a noob question:
How can you tell that my E90 engine is overheating or cold? There is no temperature gauge for the engine..?!
Any reason why BMW skipped this feature?
alaadeen is offline   Reply With Quote
Old 11-11-2013, 11:22 AM   #2
There is a warning light that comes on when the car overheats
Because oil temp is more useful, with older cars the middle of the gauge has such a huge range that it's almost like an on/off switch to keep the gauge from moving around too much and freaking out novice vehicle owners. Therefore they removed it because there is nothing to worry about until the car is actually overheating.
There is a way to see a digital read out of the coolant temp in the hidden menu, more info here:
http://e90.wikifoundry.com/page/BC+hidden+menus
Old 11-11-2013, 12:48 PM   #3
alaadeen
Thanks, T.Dot. The wififoundry link is very interesting. Will give it a shot sometime to play with the hidden display readings.
Old 11-11-2013, 03:47 PM   #4
jrsmitchell
Switchtronic
jrsmitchell's Avatar
I was also surprised that my E9x didn't have a water temp gauge.
I learned the hard way recently that the E9x DME will store "hidden" codes related to things like water temp / water pump function. So if your water pump starts to fail it will know long before you get stranded.
It's a good idea to ask your shop to check for those BMW-specific fault codes every once in a while. Otherwise don't worry about it until the dreaded light comes on.
Jeff | '94 BMW Alpina B3 | '06 BMW 325XI Wagon
jrsmitchell is offline   Reply With Quote
