Old 11-26-2013, 09:05 PM   #16
Chris916
Chris916's Avatar
Originally Posted by _JohnnyD_ View Post
Not true. I did it without touching the frame rails or the strut tower bracing and I still have a booster.
Looking back at my swap I would suggest going boosterless and using an aftermarket pedel and master cylinder system. If you are reading Garagstic's info on their website then you will be familiar with their setup.
Interesting. Everything ive read says that the frame rails need to be notched. Im going to dry fit the motor before bolting everything up so ill find out soon enough! Did you keep a/c or get rid of it?
I actually ended up buying the Garagistic motor mounts and was thinking of buying the pedal bracket and going that route, but I'm trying to keep this on a budget and that was just way too costly factoring in the pedal box + master cylinders.
I also already have the stock e34 booster so I just need to make it all work in the e30!
Also started making some progress last weekend and pulled the motor out of the 540. Planning on bringing the e30 into the garage this weekend and get going on pulling the m20 out
Track - 1991 318is - My Track Car Build
Street - 1987 340i - E30 M60 Build
Chris916 is offline   Reply With Quote
Old 11-26-2013, 09:24 PM   #17
Chris916
Chris916's Avatar
Old 11-27-2013, 10:59 AM   #18
_JohnnyD_
_JohnnyD_'s Avatar
I deleted AC. If you are keeping the AC you will need to notch the RH frame rail to fit the compressor.
The engine will fit in the E30 without AC compressor and headers no problem.
There are 2 other possible reasons to modify the frame rails.
1. Use the V8 rad. You will need to notch the LH and RH frame rail. I wouldn't recommend this at all. Buy an aftermarket rad that fits the E30 and a good fan.
2. Pocket the LH frame rail to use the 540 booster bracket and linkage. This also requires cutting the strut support.
If you are serious about building a track/race car then you don't need AC, go boosterless, and use a aftermarket rad with good warranty support. Try and keep the structure of the car as stock as possible.
“Life is a series of experiences, each one of which makes us bigger, even though sometimes it is hard to realize this...”
Henry Ford
_JohnnyD_ is offline   Reply With Quote
Old 11-27-2013, 11:12 AM   #19
Chris916
Chris916's Avatar
Sounds good. I would have liked to keep a/c but ill remove it for now since it's simpler. Yea I was thinking of using the stock e34 rad but it doesn't make much sense to notch framerails to fit it in when there are other options.
This car is remaining a comfortable summer dd/toy so I'm going to stick with the stock booster setup and modify what I need to make it work.
Check out the thread in my sig for my track car! Loved building that car so much that I decided to buy this guy for the street!
Old 11-27-2013, 11:57 AM   #20
Lercs
Lercs's Avatar
You need AC!!!! don't get rid of that for your summer car you will be disappointed!
Follow 8legs Racing on Twitter and Facebook
@8legsracing
www.facebook.com/8legsRacing
Lercs is offline   Reply With Quote
Old 12-08-2013, 05:46 PM   #21
Chris916
Chris916's Avatar
Brought the e30 in the garage last weekend and started ripping it apart.
I cut the front core support out to make it easier to remove/install motor. Ill fab up some brackets to bolt it back up.
The engine bay was so filthy. Just coated to grease.
Old 12-08-2013, 05:49 PM   #22
Chris916
Chris916's Avatar
Did some cleanup and removed the subframe, and suspension.
Lots of work still ahead. but this is a good start. I think i'll be ripping apart the interior next then getting going on fitting the e340 brake booster and linkage.
Old 12-10-2013, 01:36 AM   #23
bmwconnect
BMW Tuner
bmwconnect's Avatar
wow look how clean it is in that garage. won't last
Old 12-10-2013, 07:05 AM   #24
Chris916
Chris916's Avatar
Ha, I'm trying to keep it organized. It's easier now that shawn's not there
Old 12-11-2013, 08:22 AM   #25
Lercs
Lercs's Avatar
Originally Posted by chris916 View Post
ha, i'm trying to keep it organized. It's easier now that shawn's not there
burn!!!!!
@8legsracing
Old 12-11-2013, 08:23 AM   #26
Lercs
Lercs's Avatar
It's time to consider a change in paint colour, you won't want to paint the engine bay once that v8 is in there.
@8legsracing
Old 12-11-2013, 12:47 PM   #27
Chris916
Chris916's Avatar
I know man I've been tossing the idea around of doing a full paint job. would be so easy while everything is out of there. Just a lot of work. If I'd do it, pretty sure I would either go with BMW Steel grey or Subaru Dark grey metallic.
Old 12-11-2013, 04:24 PM   #28
sb_600
sb_600's Avatar
Originally Posted by Lercs View Post
burn!!!!!
not really, just that much less stuff and less cars in the garage.
Shawn
Old 12-11-2013, 04:24 PM   #29
sb_600
sb_600's Avatar
Do you know if the AC worked? I'd try and keep it Chris - totally worth it IMO.
notching the frame isn't a big deal - we have the tools and skills to do it - make it happen
looks awesome - keep it up!
Shawn
Old 12-11-2013, 06:05 PM   #30
Lercs
Lercs's Avatar
I know, just playing with ya :p
@8legsracing
