Old 11-02-2013, 11:31 AM   #1
gerrythegrea
code and o2 sensor help
My check engine light on my 2006 330xi was on so I went to CTire to get it diagnozed and this is what came back.
codes p2297 bank 1 sensor 2 p112c o2 sensor bank 1 sensor 1 p0131 bank 1 sensor 1 front 0-2 sensor defect upstream 0-2 sensor
they told me I needed to get an 02 sensor replaced and quoted me 340.00 for the sensor and 1 hour labour.
Does this sound about right? Can I get a cheeper sensor?
thank you
gerrythegrea is offline   Reply With Quote
Old 11-02-2013, 11:46 AM   #2
jcr
If you buy it in Canada the sensor is probably around $150?
If you buy it from the USA it is less than $100...
So you need the upstream sensor?
jcr is offline   Reply With Quote
Old 11-02-2013, 12:32 PM   #3
gerry,
look up your part numbers on realoem.com with your vin
(bmw called o2 sensors lambda sensors)
buy OEM bosch sensors on ebay/rockauto/etc for less.
Old 11-02-2013, 12:33 PM   #4
jcr
I say check out rock auto. way cheaper
Old 11-02-2013, 02:18 PM   #5
gerrythegrea
I m no mechanic and dont know what sensor I need Is there a way to know so I can order the right one?
Old 11-02-2013, 02:40 PM   #6
jcr
Kind of strange when I look up
P2297 it should be sensor 1 but your have it as sensor 2
Anyway don't quote me on it but I think it is the upstream on (The one on the exhaust manifold).
RockAuto has it for around $57 + shipping
Old 11-02-2013, 02:44 PM   #7
gerrythegrea
I copied from the CTire paper. If they are both that price I will get them both changed. I did a parts number search on Rockauto and cant find them
Old 11-02-2013, 02:50 PM   #8
jcr
well CT is never that great of a place.... You should look into getting a cable yourself. They're fairly cheap. Considering how much you paid to get a code check, 1-2 code check from a shop can already pay for the cable.
Anyway RockAuto has the Upstream O2 for $47 and downstream O2 for $57. Plus shipping and any duty. Still cheaper than getting it local. You might as well pick up filters too if you need them they're cheap there too.
Old 11-02-2013, 02:56 PM   #9
gerrythegrea
parts number : 11787545075
227$ for me something I m doing wrong?
