Old 10-26-2013, 09:49 PM   #1
barbarian
Xenon Issues 2001 e46 325i
Hi guys,
I know i've posted about this a while ago but thought I would update everyone on my xenon situation and ask a few more questions.
My xenons were flashing on/off forever. I bit the bullet and changed the alternator (which needed to be changed anyway), got a brand new battery (directly from BMW) and that DIDN'T fix the problem.
I swallowed my pride and paid the $200 to have BMW run a diagnostic. They told me that I need to use BMW bulbs in my tail lights and not any from Canadian Tire and etc. they said it didn't completely solve my problem but made it better. Now my xenons only flash every few minutes once and then stay back on. It was suggested by BMW that I should replace the entire headlight system for a mere $2500!!!!
Is that really necessary? Or can I just buy an HID CAN-BUS kit and replace it like that? I also want angel eyes, so I was wondering if I installed those would that fix the problem?
I'm at my wits end here. Please help!
barbarian is offline   Reply With Quote
Old 10-26-2013, 11:30 PM   #2
The problem is most likely a bad ground at the tail lights, VERY common problem and BMW even had a recall on it, and upgraded bulb holder with extra ground cable. In rare cases the headlight switch (module) can also do this.
Another common problem with the flashing HID's is the ballast or igniter, but if BOTH lights do it at the same time, i would look at the ground/module first.
As to the aftermarket lights, most are complete garbage, would never put or suggest anyone putting it on a BMW. They leak, fail, and in some cases melt or catch fire. I have seen melted aftermarket ballasts only after a year!
Old 10-26-2013, 11:47 PM   #3
barbarian
Ok. Where do I start? I'm reading what you're saying clearly but not understanding ANY of it...where do I find this tail light ground? And if there was a recall done on this would they not have told me about it at BMW or even been done already, therefore NOT silving the problem?
Old 10-27-2013, 12:54 AM   #4
The sad reality is that most people working at dealerships don't know jack! Plus they rather sell you $2500 worth of parts!
Best thing to do is bring it to an independent shop that does BMW only. They will be able to figure out what the problem is, and the best solution. Check the sponsor page, few other shops not listed can do a great job too.
You can also Google the problem, to get an idea, but don't trust 100% of the things posted on the internet! (use just for BASIC info on the possible causes).
Old 10-27-2013, 05:53 PM   #5
jabela
Yea, dealership is the last place your should go. If you're not confident working on it yourself, take it to a recommended shop, like RMP or another forum sponsor.
www.maisonapothecare.ca
Old 10-27-2013, 06:02 PM   #6
wire your lowbeams with a relay directly to your ignition. your lowbeam HID's will be your DRL.
Total cost ~15$ parts, 100$ labour.
