Welcome to!
Old 10-09-2013, 01:37 PM   #1
Anyone successfully running ACS w/ M50 manifold on OBDII M3
I have heard that people have disconnected their motor for ACS due to the larger Manifold and the way it sits in the engine results no way to connect ACS. Could anyone verify this and can your ABS work without the ACS connection?
Reason I ask, I am having continuous ABS issues and difficult to trace the actual cause.
Current Cars:
1997 M3 Coupe
2011 Chevrolet Avalanche
2007 Subaru Impreza
Past Cars:
2010 GMC Terrain
1998 BMW 328is
2006 BMW 325i
2007 Saab 9-3ss AERO
2004 Saab 9-3ss Linear
2003 PT Cruiser
2001 Volvo S40
1990 Honda Accord EX-R
brunp is offline   Reply With Quote
Old 10-09-2013, 03:00 PM   #2
SickFinga's Avatar
When I switched to M50 manifold I did not have to remove the ASC. Everything worked fine. I did have to remove it when I installed a supercharger since there is no room for it. So to answer your question, ABS works fine without the ASC
Old 10-09-2013, 03:05 PM   #3
If you reuse the throttle body and buy the kit with the adapter to use the OBDII throttle body then you can retain ASC.
If you switch to an OBDI trottle body then you've essentially removed it.
I had ASC for a while after I did the swap until I removed it.
