Old 09-27-2013, 01:44 PM   #1
civic_eater
civic_eater's Avatar
My m50 vanos won t start
First the car wouldn t idle and had a miss. I changed coils plugs maf and the iac and still no difference.. Then i changed the injectors and rail. But now car won t start and fuel pump isn t getting power i have spark and even when i jump the pump to get it running the car still doesn t start please help!!!!!also when im turning it over my rpm gauge jumps all over
civic_eater is offline   Reply With Quote
Old 09-28-2013, 05:48 PM   #2
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Crank sensor.
Old 10-19-2013, 09:02 AM   #3
SirVemup
HP Maniac
Did you get it running?
SirVemup is offline   Reply With Quote
Old 10-23-2013, 03:00 PM   #4
civic_eater
No i had a short in the engine harness so i swapped it out i havn t pit it back together completely yet, but i wasn t getting power to the fuel pump or injectors what would cause that??
Old 10-23-2013, 08:06 PM   #5
SirVemup
HP Maniac
I have the same symptoms as you explained in your first post. I replaced the fuel pump and nothing. Some hillbilly mechanic told me i need the timing chain redone (VANOS). Did you try the crank sensor like AXXE suggested?
Old 10-24-2013, 02:35 PM   #6
civic_eater
I will try it.
