Old 09-23-2013, 10:18 AM   #1
El Gato Liso
El Gato Liso's Avatar
Passenger window stuck in down position help
Hi
Still being relatively new to e46. I encountered what had put me in a pickle.
I was driving last night and as i put the window down a bit, it went down on its own. I flicked up on the switch but it just kept going down.
Now the window is stuck open. Every time i push or pull the window switch, i can hear the tick in the motor
I am totally stumped and cannot even move the window up by hand
R.I.P. E30
Old 09-23-2013, 12:22 PM   #2
Lercs
Lercs's Avatar
search for window regulator and I'm sure you will find some good info on how to replace.
Follow 8legs Racing on Twitter and Facebook
@8legsracing
www.facebook.com/8legsRacing
Lercs is offline   Reply With Quote
Old 09-23-2013, 12:43 PM   #3
dtthiaga
Welcome to the E46 Design Flaws.
It is most likely related to the window regulator itself. There are a lot of plastic in the regulator, and it is of very poor quality.
I compared the E46 with a Hyundai Accent one, and I think the Hyundai one is stronger.
It's that bad. It doesn't align well from the Factory.
The ebay ones are of the same quality as the factory ones. I bought all 4 just in case back in the day.
Even after one warranty replacement of a regulator, I think I used 3 out of the 4 that I bought as spares.
For now, you should open the door panel up, and push the window up. Depending on what is broken, I would put a screw/bolt in the regulator to hold the glass up.
There are several DIY's...
http://forum.e46fanatics.com/showthread.php?t=356847
http://www.pelicanparts.com/BMW/tech...eplacement.htm
Also.. buy some Rust proofing, and spray the inside of the door.
E46's rust from the inside out. You might as well spray the inside of the door seams while you have the chance.
