Old 09-24-2013, 05:37 PM   #16
jabela
Looks like it was a stuck throttle.... also here's the aftermath.
www.maisonapothecare.ca
Old 09-24-2013, 08:45 PM   #17
canukgtp
canukgtp's Avatar
crazy...at least they made it out ok
canukgtp is offline   Reply With Quote
Old 09-24-2013, 10:10 PM   #18
davericher20
black and blue
davericher20's Avatar
Looks to me like driver error.
#armchairracing
Old 09-25-2013, 01:23 PM   #19
FermiParadox
FermiParadox's Avatar
Originally Posted by jabela View Post
They're lucky they landed in the water. It was certainly softer than landing on solid ground upside down.
Due to the highly incompressible nature of water it's likely that that impact would be more catastrophic than hitting the ground...
Sent from my SGH-I747M using Tapatalk 2
FermiParadox is offline   Reply With Quote
Old 09-26-2013, 03:56 AM   #20
El Gato Liso
El Gato Liso's Avatar
^ well it isnt that actually. It is simply the cohesion of hydrogen on the surface of water. Smack it...it hurts. Put ur hand thru it nice and easy, its soft.
R.I.P. E30
Old 09-26-2013, 10:54 AM   #21
FermiParadox
It's exactly that actually. One can talk about cohesion of molecules which is the cause of surface tension but that has no bearing on the resistance of a substance, in this case water, to compression. You can put soap in that water to decrease the surface tension all you like but it won't help you with the incompressible nature of water when you hit it at high velocity. Water is viscoelastic meaning that its response to deformation is time (or velocity) dependant which amplifies the effects of impact when considering that it already has an extremely high bulk modulus of 2.2 GPa under static conditions.
QED
Old 09-26-2013, 11:03 AM   #22
slemmer
Driving in the fast lane
slemmer's Avatar
I knew I should have paid attention in Chemistry and Physics
'15 Ford F150 Lariat SCSB 4x4
'04 645cic
'00 740i Sport
Old 09-26-2013, 11:23 AM   #23
davericher20
black and blue
QED
Old 09-26-2013, 01:05 PM   #24
325isdan
DaveRicher - exactly what I was thinking while reading that. lol
325isdan is offline   Reply With Quote
Old 09-27-2013, 12:04 PM   #25
EMPOWERD
EMPOWERD's Avatar
Originally Posted by Robb View Post
Porsches are too heavy for that kind of racing.
You need a nimble car or AWD.
Rob, haven't seen some keyboard-diarrhoea from you in a while.. nice of you to throw some out for a change. Verifies that you haven't learned a thing these past 12yrs.
My YouTube video
-- RANDY SPARRE --
Old 09-27-2013, 12:57 PM   #26
jabela
How would it be more catastrophic to hit water? (other than possibly drowning)
Solid ground isn't more compressible. The water will more easily be flow out of the way, resulting in lower peak deceleration rates.
That's why these shallow pool high divers aren't dead.
Old 09-27-2013, 01:38 PM   #27
SickFinga
SickFinga's Avatar
That would be true if there was place for water to escape. In this case, water definitely cushioned the impact.
Old 09-27-2013, 06:59 PM   #28
FermiParadox
I don't want to be rude but if you knew anything about physics you'd know that you just proved my point for me with that video as it demonstrates the incompressibility of water.
Old 09-27-2013, 07:11 PM   #29
FermiParadox
Again, the damage associated with landing on concrete would be measured in terms of a single impact which is not true when impacting water. As the car hits the water it will encounter a very large number of impacts as it shears the water out of its path. The result will be large shear, or drag gradient which will result in chassis deformation as is visible in the post-crash photos.
Old 09-27-2013, 07:27 PM   #30
jabela
I wasn't disagreeing with the incompressibility of water. I was asking why you think hitting the ground would be worse.
And yes, have studied physics.
