Old 09-19-2013, 02:59 PM   #1
slemmer
Driving in the fast lane
slemmer's Avatar
Rad replacement
I started to develop a leak in two places of the left plastic casing of my rad. Is this piece replaceable or do I need to replace the entire rad? If the plastic piece is replaceable is this something a DIY'er can do or should it go to a rad shop?
Stephen
'15 Ford F150 Lariat SCSB 4x4
'04 645cic
'00 740i Sport
Old 09-19-2013, 03:19 PM   #2
Unless you are talking about the overflow tank, no, the plastic sides of the rad are not replacable. If you need a rad we have several in mint condition.
Old 09-19-2013, 04:47 PM   #3
slemmer
slemmer's Avatar
Nope, I change that one thinking that was the most common problem but the old one was still ok. I thought I figured it out from the o-ring for the temp sensor but it appears there was another leak elsewhere. Only think left to do is the water pump and rad and I should be good for another 12 years I should have time this evening to start the disassembly process.
'04 645cic
'00 740i Sport
Old 09-19-2013, 10:44 PM   #4
mtnbiker
Im in a similar situation. Where are you looking to but the rad from?
[SIGPIC]
mtnbiker is offline   Reply With Quote
Old 09-20-2013, 01:37 PM   #5
Buy a Zionsville setup and never have to worry about cooling leaks ever again!
Old 09-20-2013, 04:26 PM   #6
slemmer
slemmer's Avatar
Wow, that will outlast the car!
'04 645cic
'00 740i Sport
Old 09-20-2013, 04:30 PM   #7
slemmer
slemmer's Avatar
Since the rad is a critical component I've decided to source and pick up current product from the US. The cost of a recycled part is lower however I may have the same problem reoccur sooner than later. Can't take that chance.
'04 645cic
'00 740i Sport
