Old 10-04-2013, 02:42 PM   #16
Sea Aych
Sea Aych's Avatar
Originally Posted by propr'one View Post
^^yes but i think you should try to find someone who uses a thicker product. the krown stuff is so runny half of it ends up on your driveway after you get it done.
yuppers. I've heard good things about Fix Auto as someone mentioned further up in the thread
Sea Aych is offline   Reply With Quote
Old 10-04-2013, 05:14 PM   #17
alvin1344
Is rustproofing needed if the car is going to be stored winter?
alvin1344 is offline   Reply With Quote
Old 10-04-2013, 07:13 PM   #18
iverson03tj
iverson03tj's Avatar
depends how you store it, if its in a heat garage away from any moisture then your fine.
even if its in an un heated garage, as long as you give it a good wash before winter, let it dry and store it, you should be fine..
All cars will rust, you just gotta prolong the period before it rusts.
e39 M5 (s62)- Muffler Delete, Timmay Tips,
e30 325ic - Hard Top, Matte Black
e36 328is - (m52)AA S/c'd, M50 Mani, 3.23 LSD, M3 Brakes, Zimmer rotors, hps pads, Racing Dynamic Strut Bar, Depos, m3 Bumper, Intake, Spal fan, poly RTABs, Eibach Swaybars, Koni yellow, Mishimoto Rad, Silicone hose, Alumi T-housing, Depo w/LED Angels, LED tails, 12' Alpine Type R, Suede head liner, LTW Low rise spoiler
PREVIOUS CARS
92' 325is (m52) - M3 conversion AA S/c'd
'97 Euro Estroil E36 M3 Vert (S50B32)
Old 10-04-2013, 09:01 PM   #19
jcr
I had the thicker stuff at the Fix It Auto in Oshawa. It was ok but man it was hard to wash off the extra run-off oil on the body.
jcr is offline   Reply With Quote
Old 10-05-2013, 08:33 AM   #20
windwagen
windwagen's Avatar
The Rust Chek cans at crappy tire are better than oil. This stuff is formulated for this purpose, not primarily lubrication...
Runny / thick - it's a catch 22. You want it to be runny so it seeps into the "nooks and crannies". also, the misting action, whether froma can or professional is beneficial...yeah, it gets everywhere.... which is prolly what you really want for rustproofing - no?
Old 10-05-2013, 01:59 PM   #21
aviator
No body mentioned this but after you get it sprayed remember not to wear light coloured pants for a week or two... there will be seepage and it will get on your pants getting in and out. As for your wife/partner/date/co-driver warn them or not it's up to you lol...
aviator is offline   Reply With Quote
Old 10-06-2013, 10:45 AM   #22
kenmar
On E90Post, there's no real consensus as to whether rustproofing is needed because they doubled the corrosion warranty compared to the E46. I assume they upgraded the body panel materials to a more rust-resistant metal. Also note that the E90 has plastic under panels, but I'm not sure if that's a benefit or drawback (i.e. does it trap salt-laden moisture?). You see lots of rusty E36/E46's around, but not too many E90's. Is it just a matter of time? The E90 has been on the road for ~7 years now and I assume rust should be hitting cars within 4-5 years of winter driving (my experience).
There is still the added benefit of rust-proofing making dissassembly of nuts/bolts much easier: I never had any snap on my E36 which was Krown'ed annually. This benefit has to be weighed against having a cosmetic hassle of having constant drip from the doors onto the rockers that persists even into the summer.
Old 10-06-2013, 11:48 AM   #23
LOSO
Just wash your car every week at the coin wash, and make sure you get the underbody.
LOSO is offline   Reply With Quote
Old 10-06-2013, 02:17 PM   #24
kenmar
That doesn't really prevent inevitable rust from occurring; it just reduces the severity of it. I tried that on my old Mazda that was purchased new and it still started to rust.
Old 10-06-2013, 04:11 PM   #25
I'm looking for a good shop to do this as well.
Old 10-06-2013, 07:48 PM   #26
windwagen
windwagen's Avatar
Or don't wear any pants at all!!! Go naked....my wife didn't fall for that one
Old 10-06-2013, 09:14 PM   #27
You need chloroform bro.
Old 11-09-2013, 05:48 PM   #28
Oyster
Send a message via MSN to Oyster
I used Krown rust control on laird street every year
Sent from my iPad using Tapatalk
Oyster is offline   Reply With Quote
Old 11-10-2013, 11:17 PM   #29
iverson03tj
is there such thing as clear under coating?
PREVIOUS CARS
Old 11-11-2013, 02:36 AM   #30
aviator
There is clear rocker panel coating that leaves a ripple-ish finish that is sometimes used as undercoating, but I have to ask why would you care if the under coat is crystal clear or slightly opaque [like krown or others] the only folks who will ever see it are usually there to do a job fixing something not taking a tour...
