Old 09-19-2013, 02:52 PM   #1
1bmw1
Rust proofing, Undercoat. Who's the best? Where to go?
Since winter is approaching, where do you guys suggest to get my car rust proofed? Does RMP still do this? Any suggestions appreciated.
P.S. I don't want holes being drilled.
Old 09-19-2013, 03:03 PM   #2
RMP does still do this, saw a tub of the stuff there last time i was around, give lauren a call.
AFAIK the e90 has plastic covers on holes to get stuff into doors and fenders, no one should be drilling holes
Old 09-21-2013, 04:25 PM   #3
windwagen
windwagen's Avatar
If the holes are already there, just get a can of Rust Chek from Crappy Tire and go at it!
Old 09-21-2013, 06:31 PM   #4
1bmw1
Thanks for the info. Any experiences with krown?
Old 09-21-2013, 08:01 PM   #5
windwagen
windwagen's Avatar
I got Krown to drill the holes in wifey's Odyssey. Then I use the rust chek can the following years. I can't complain....
Old 09-21-2013, 10:37 PM   #6
aviator
I would go with Krown, good product, and usually careful competent applicators but check their work before you let them at you baby. The Krown off Torbram? Bramalea? N. of Derry is a good one as is the one on the N. side of St. Clair E. between Danforth and Midland.
aviator is offline   Reply With Quote
Old 09-22-2013, 04:19 PM   #7
alaadeen
Probably, a trivial question, but what do you mean by drilling holes? Sorry I am new to this kind of rustproofing process.
alaadeen is offline   Reply With Quote
Old 09-22-2013, 11:18 PM   #8
aviator
When the rust proofing chemical/oil is first applied they drill holes in the door sill [to access the inside of the rocker panel], rear door frame [to access the area below the c and/or b pillars], the upper door frame [to access the b pillar], and the front door frame [to access the lower A pillar and door hinge mount area], and the rear frame of the door itself [to access the inside of the door] they use these small [typically 3/8" */-] holes to stick the applicator wand in and then plug them with plastic plugs that they pull out and replace each time you go back. Once installed they are typically fairly unnoticeable if they put them in the right place [a good shop will do this, a bad one not so much] for example the po of my truck had it done and they drilled the rocker holes too far out and you could see the edge of the plug under the closed door, when I had Krown on St. Clair E. do my old truck you had to look carefully to find the plugs they were so well hidden.
Hope this clears things up for you.
Old 09-30-2013, 10:58 AM   #9
Jay22
Shadows.
Jay22's Avatar
Im looking to do this as well on the E90 before I store her away at the end of october. Anyone got theirs done with RMP ? How did it go and hows the pricing?
Jay22 is offline   Reply With Quote
Old 09-30-2013, 11:24 AM   #10
SiR
Vtec just kicked in
regs is good
-||Old Crayons||-
Old 10-03-2013, 09:24 AM   #11
Sea Aych
Sea Aych's Avatar
Bump. I'm also interested considering the ludicrous amount of salt the put on the roads around downtown
Sea Aych is offline   Reply With Quote
Old 10-03-2013, 07:51 PM   #12
jcr
Not a fan of Krown (the one on Parliament). On my previous car, when they were driving on the ramps, they weren't center and slide my car off the side...
Fix Auto in Oshawa was pretty good
jcr is offline   Reply With Quote
Old 10-03-2013, 08:08 PM   #13
Sea Aych
Sea Aych's Avatar
Yeah me n'either. Last car i had (Mazda 3) they totally over did it and ruined the interior of my trunk, and it leaked all over the place for months...I mean i'm sure that may have been a one off thing...but still. Hence my looking for alternatives for this time around!
Old 10-04-2013, 11:10 AM   #14
iverson03tj
iverson03tj's Avatar
I got to do this soon... so is the best rust proofing oil?
e39 M5 (s62)- Muffler Delete, Timmay Tips,
e30 325ic - Hard Top, Matte Black
e36 328is - (m52)AA S/c'd, M50 Mani, 3.23 LSD, M3 Brakes, Zimmer rotors, hps pads, Racing Dynamic Strut Bar, Depos, m3 Bumper, Intake, Spal fan, poly RTABs, Eibach Swaybars, Koni yellow, Mishimoto Rad, Silicone hose, Alumi T-housing, Depo w/LED Angels, LED tails, 12' Alpine Type R, Suede head liner, LTW Low rise spoiler
PREVIOUS CARS
92' 325is (m52) - M3 conversion AA S/c'd
'97 Euro Estroil E36 M3 Vert (S50B32)
Old 10-04-2013, 01:14 PM   #15
^^yes but i think you should try to find someone who uses a thicker product. the krown stuff is so runny half of it ends up on your driveway after you get it done.
