Old 09-19-2013, 11:41 AM   #1
aa34s
Engine heat comes into interior
I got a 99 328i and just found out that the engine heat comes iinto the interior when the engine in normal temp. Even I turn the temp to the lowest, it's still blowing warm air.
Can anyone give me some ideas??
aa34s is offline   Reply With Quote
Old 09-19-2013, 11:43 AM   #2
Old 09-19-2013, 12:08 PM   #3
iverson03tj
iverson03tj's Avatar
^^^^ +1
e39 M5 (s62)- Muffler Delete, Timmay Tips,
e30 325ic - Hard Top, Matte Black
e36 328is - (m52)AA S/c'd, M50 Mani, 3.23 LSD, M3 Brakes, Zimmer rotors, hps pads, Racing Dynamic Strut Bar, Depos, m3 Bumper, Intake, Spal fan, poly RTABs, Eibach Swaybars, Koni yellow, Mishimoto Rad, Silicone hose, Alumi T-housing, Depo w/LED Angels, LED tails, 12' Alpine Type R, Suede head liner, LTW Low rise spoiler
PREVIOUS CARS
92' 325is (m52) - M3 conversion AA S/c'd
'97 Euro Estroil E36 M3 Vert (S50B32)
Old 09-19-2013, 12:39 PM   #4
aa34s
yes, I set it in cool (blue dot) but still blowing warm air.
Old 09-19-2013, 12:48 PM   #5
Quack
Wheelman
Quack's Avatar
not sure what it is called on a BMW but most european cars have this part, on a Mercedes it's either called a mono-valve or duo-valve, it lets coolant into the heater box to warm up the vehicle, when the valve fails it's normally stuck open, so even when you have the heat off & the A/C on, it's still letting hot coolant into the heater box, it will normally come up as a fault if you scan your vehicle.
Old 09-20-2013, 07:46 AM   #6
kenmar
I have the same problem (on my E36, though); it's supposed to be the heater control value on the firewall behind the engine (not too accessible and $$$). There's an E36 thread on bimmerforums http://forums.bimmerforums.com/forum...ater-valve-DIY. Complete with pics.
Old 09-20-2013, 09:03 AM   #7
e30drifter
SLYDWAYZ
e30drifter's Avatar
Does your heater work properly? Or act funny? I had the same problem. My heater control kinda worked. For the most part it would be on. Temp set to the coolest, fan on 1. I wouldn't get much heat from the dash but the engine temp would start to run really hot. At time my heater unit would stop working and I would have to smack it for it to come on. But when in the not working position I would get extreme heat coming from my dash and my car would not overheat when idling. Or those two situations could have been vice versa heater control working or not working. I can't remember. But either way It was either me overheating or my car overheating. I also had some kind of temp/censor code. I changed my heater control unit and no more problem and the code went away. I never knew about that heater switch at the firewall. I always thought it could be something like that, that could haven causing this issue and not the heater control. I guess in my case I got lucky?
Old 09-20-2013, 09:21 AM   #8
e30drifter
SLYDWAYZ
e30drifter's Avatar
Forgot to mention that my auxiliary fan would not come on when idling if my heater control unit was on or not working, I can't remember. But I do remember my car would Idle differently when I would unplug and plug it back in. It wasn't a huge difference. Only noticeable when the car was running. my replacement unit has no effect on idle.
Old 09-20-2013, 09:26 AM   #9
e30drifter
SLYDWAYZ
e30drifter's Avatar
Oh shit. I just noticed this is in the e46 section. My car is an e36. Sorry for any confusion I may have caused
Old 09-20-2013, 03:48 PM   #10
aa34s
Thanks for all the replies.
I used the scan tool but no fault codes.
It's normal if I turn on the heat, but it blows warm air when I set to the low temp.
My A/C is not working now and I took out the belt for the A/C. Will it affect the heating system??
Thanks again.
