Old 09-18-2013, 03:33 PM   #1
matt123494
matt123494's Avatar
brake booster question
does anyone know if you can use a normal e30 brake booster on a m3? apparently there are no more available in stock anywhere even in germany and mine recently crapped out on me. if you cant use a normal e30 booster are there any other options?
matt123494 is offline   Reply With Quote
Old 09-18-2013, 04:47 PM   #2
Yamahammer
Warlock of the century
Yamahammer's Avatar
If you look the assemblies up the master cylinders apparently have different bores (20.64 - non m vs. 23.81 m).
I did a quick search and found this:
http://www.r3vlimited.com/board/showthread.php?t=293169
and
http://e30tech.com/forum/archive/index.php?t-71217.html
Apparently the booster will bolt up. However a non M MC cannot be used as the brake line threads are different.
