Old 09-15-2013, 02:52 PM   #1
matt123494
matt123494's Avatar
Exclamation urgent brake question!
when i got home today from a car cruise when i parked my car and turned it off i pressed the brakes and it sounded like air was escaping from behind the pedal. so i turned the car back on and i could still hear the noise a bit when i braked. is this a problem could this mean the braking system could have a issue. please help.
matt123494 is offline   Reply With Quote
Old 09-15-2013, 03:42 PM   #2
cormier
cormier's Avatar
Is your res full? When was the last time the fluid was changed or bled?
Old 09-15-2013, 04:14 PM   #3
matt123494
matt123494's Avatar
last time was about 16 months ago. also it is full.
Old 09-15-2013, 07:24 PM   #4
bimmere30
hello
thats what the good ol e brake is for, got mine already fixed. have no clue why it would sound like air when pressed. does it sink and have no pressure at all. Re bleed your brake again.
bimmere30 is offline   Reply With Quote
Old 09-15-2013, 11:09 PM   #5
matt123494
matt123494's Avatar
there is still pressure like it is drivable on the road but there is just the sound.
Old 09-16-2013, 07:24 AM   #6
cheapthrills
Pumping the brakes when the car is off normally makes a squishy air sound. Pump it 5-10 times with the car off and the pedal should get hard.
cheapthrills is offline   Reply With Quote
Old 09-16-2013, 07:40 AM   #7
BigD
the misanthropist
BigD's Avatar
http://auto.howstuffworks.com/auto-p...ower-brake.htm
Old 09-16-2013, 05:15 PM   #8
SamE30e
SamE30e's Avatar
It's the brake booster. You don't hear it when it's running because the engine drowns it out, and it's under vacuum...
If your brakes work like normal, you shouldn't be concerned.
85 325 - Turbo M52B28.
