Old 09-16-2013, 10:44 AM   #16
Ok, the seller is an idiot. 99% of the time, a person inspects the car, if they like it they will leave a deposit and come later that day, or in a few days with the rest of the funds. If the buyer doesn't return, or changes his mind, the seller keeps the deposit and re-sells the car. Simple, very simple. If he *really* removed the bulb for the check engine light ( I don't believe that is possible because they are LED's that are soldered to the motherboard of the cluster), than that is about as slimy as it gets. It is very possible there are codes that are stored that have not tripped the check engine light, evap codes or coolant temp codes are very common to behave that way.
In any case, original poster, you really need to work on your typing, it took me a couple of tries to understand what the hell you are saying.
Old 01-07-2014, 11:55 PM   #17
windwagen
windwagen's Avatar
Bulb test.... Turn the key to on position without starting. All the lights should light up. Works on all cars.
Old 10-26-2015, 08:23 PM   #18
24vofTouring
betterwiththebackendout
English language is a real challenge these days. Especially when you are trying to type on your blackberry. or may b u fail grade 3.
1988 e30 325i Touring 5speed 3.73LSD conversion - MalachutGrun Metallic
1991 e30 318is 4.10LSD - DS Black
1995 e34 540i/6 Touring conversion - Schwartz Black
1992 e34 525i Touring 5speed 3.46LSD conversion - Island Grun Metallic
24vofTouring is offline   Reply With Quote
