Old 09-08-2013, 03:17 PM   #1
Wes_R
F430 x Wes_R (72 pics)
Hey MaxBimmers,
Here is a new write up on a black on black on black F430 lol. A long time e46 M3 client referred this gentleman to me and after exchanging a few emails back and forth and a phone call we finally got the Ferrari in the shop.
Here is the Prancing Horse on arrival
Starting with the wheels was the usual prep routine
We used our angle brush to reach into the wheel well
And clean the tire wall
Cleaning inside the lugnut area
Wes_R is offline   Reply With Quote
Old 09-08-2013, 03:17 PM   #2
Wes_R
The calipers
And finally rinsing everything off with our angled power washer extension
The exhaust was cleaned as well
First outside the pipe with our Mini Ez Brush
Then inside with 0000 steel wool
Here is a before and after shot
Before
After
Finally we can wash the car
Starting with a rinse
Two bucket method always used
Washing with a natural sea sponge
Rinsing off the dirt in the water only bucket before putting it back in the soap bucket
Old 09-08-2013, 03:18 PM   #3
Wes_R
Taking care of the little details
Door jambs
And before drying off the paint was clayed to remove embedded dirt in the clearcoat
Pretty dirty
After drying measurements of the paint thickness were taken to ensure we had healthy levels to work with
Everything was looking good and there were no signs of repaint
Next was to mask off the rubber trim to protect it from staining or being burnt by our buffer
Old 09-08-2013, 03:18 PM   #4
Wes_R
The paint was in fairly rough condition and after a few test sections I decided to go with Meguiars Microfiber cutting pad and compound
Here is a shot of me polishing
And the befores and afters
Before
After
Before
After
Before
After
Before
Old 09-08-2013, 03:19 PM   #5
Wes_R
After
Before
After
Before
After
Here is a quick 50/50 on the passenger's door with the right polished and the left side untouched
Also the taillights were polished as well
Before
After
The 2nd stage was carried out with a light cutting pad and polish and the whole car was polished again for the 2nd stage to refine the finish and bring out the deep gloss
After the 2 stages of polishing were completed the masking tape was removed
Old 09-08-2013, 03:20 PM   #6
Wes_R
And the paint alcohol wiped to remove the polishing oils
I double checked the paint with my Infratech which produces the same color light as the sun
No more swirls
Here is a teaser of the shine achieved
Opti Coat was used to protect the paint. If you are not familiar with Opti Coat, it is something different from a wax or sealant. It is actually a coating and to be more exact a resin based coating that behaves like a wax and is permanent. What's great about the protection that it offers is, it is chemical resistant which means things like bird droppings will no longer burn into your paint and leave that nasty staining. Also it is very hard, on the pencil hardness scale it is 9H which doesn't mean it is invincible but if you maintain your car properly you can keep it swirl free for life!
There are many other great features about Opti Coat but those are the main selling points. If you google it and do a little research you will see quite a few extensive test on Youtube and other forums.
The Diablo in the background was just Opti Coated as well.
While the Opti Coat was curing other areas were attended too
Like the windows
And dressing the tires
Finally with everything completed, the finished pictures.
First off a shot in the sun to show no swirls in the paint.
Old 09-08-2013, 03:21 PM   #7
Wes_R
A little sun flare in this shot
Old 09-08-2013, 03:21 PM   #8
Wes_R
I love the reflections in this pic
And finally the last pic of the walkaround
I hope you guys enjoyed reading through the documentation as much as I enjoyed working on this Prancing Horse.
Old 09-08-2013, 10:28 PM   #9
Robb
EX E30 M3 Owner
Robb's Avatar
Perfection. again.
Those buckets, you can use grit guards !
Robb is offline   Reply With Quote
Old 09-22-2013, 03:58 PM   #10
Wes_R
Thanks Robb
Old 09-22-2013, 04:16 PM   #11
alaadeen
This is amazing detailed stepwise detailing with actual photos!!
alaadeen is offline   Reply With Quote
Old 10-13-2013, 07:57 PM   #12
Wes_R
Thanks!
Old 10-13-2013, 09:45 PM   #13
Great work, as always.
I should have you Opti Coat my E39 next summer.
Old 10-20-2013, 11:58 AM   #14
Wes_R
Forget next summer, let's do it now! Imola red is my favourite color for the e39 M5!
Tags
orion detailing co, toronto detailer, toronto detailing
