Old 09-05-2013, 12:13 PM   #1
N.V. Auto
1987 E30 Coupe 5 Spd 325
Hi there,
I have for sale a 1987 BMW E30 325e 5 Speed Coupe.
I bought this last year, to build as a Daily Driver, as I've always wanted a E30, but now I've just picked up a low mileage Porsche, and no longer need this E30.
Car has 202,600 KM on, it when I bought it, the timing belt was snapped and some of the valves were bent. It's running now and running strong with a lot of new parts:
- 12 Brand new valves
- Brand new valve seals
- Cylinder head cleaned and built by Athenia Machines in Hamilton
- Brand new head gaskets
- Brand new head bolts
- Brand new Gates timing belt & tensioner pulley
- Brand new thermostat & gasket
- Brand new accessory belts
- Brand new spark plugs
- Brand new cap & rotor
- Tires are like new, only has about 5,000 KM on them
- Brakes are very good
- Brand new Spal racing fan to replace the clutch fan
- Brand new alignment
- Underneath of the car is beautiful, everything is solid, no rust in the floor, car has been rust proofed recently
- Typical crack on the dash, but the interior is super clean. Front driver seat has a tear.
Asking $3500 OBO, price is negotiable as I need this gone ASAP.
Please email namvcn@hotmail.com or call/text (905) 870-5550 if you want to see the car, I'm located in Hamilton.
I can email more pictures of the underneath, the floor and the battery tray if you like.
Thank you, Nam
N.V. Auto is offline   Reply With Quote
Old 09-05-2013, 02:34 PM   #2
Woofer
Woofer's Avatar
Is it an eta or an "i" model?
The pic of your tach shows 7k redline. If I'm not mistaken, the eta is suppose to have a 5k redline?
Good luck with sale. If its an 87 "i" model you should correct your thread, May get more bites as the "e" motor is usually not that popular.
Old 09-05-2013, 02:57 PM   #3
Intake manifold is eta
Old 09-06-2013, 01:46 PM   #4
N.V. Auto
The redline actually starts at 6250 rpm.
I punched the VIN into BMW VIN Decoder and it says its definitely a 325e.
Was told these are the heads you need if you want to build a stroker, and because its a 87 you don't need any etest.
Old 09-06-2013, 02:01 PM   #5
So it's got the head off a 325i on it then? It's a common thing to do with the 325e.
The factory tach for the 325e only goes up to 5000rpm
Old 09-06-2013, 04:10 PM   #6
Ceeker
the ETA and super ETA are slightly different. I believe it has to do with the rod throw. As I understand, the super eta comes with the I head and intake manifold and not the "E" intake. I believe this would also apply to the "eta" models if it were changed. Bmw did install 2.7ltr engines in cars otherwise supposedly needing a 2.5 I have come across this quite a bit in the past and was stumped. I later found out that at some point bmw had a shortage of blocks therefore fitting the 325i with a 2.7 block and 2.5 cylinder head and intake.
I drove a 4 door 325i which went like stink..couldn't figure out for the life of me until I found out the block was a 2.7 litr. I also came across one recently in a vert. where the the car had a 2.7 litre motor. perpendicular side mount oil filter gave it away.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 09-06-2013, 04:31 PM   #7
The car is an '87 though so it can't be a seta. The seta was '88 only right?
Old 09-06-2013, 07:07 PM   #8
e30_kid89
The Afro-stig
e30_kid89's Avatar
correctomundo
