Old 08-30-2013, 10:56 PM   #1
<3MyE36
-Richy Nevaless-
<3MyE36's Avatar
HELP! E36 Problem
Hello, Everyone my brother just bought a 97' 328i (AUTOMATIC) with 127,000 kms, BUT We have a major problem, The TRANSMISSION WILL NOT SELECT ANY GEARS Does anyone know what the problem could be or provide some possibilities? Could it be a transmission problem? Shifter Cable or The Gear Selector itself? ANY help would be greatly appreciated. After this all we have to do is replace the Head gasket which we already know how to do because we did mine. THANKS !
<3MyE36 is offline   Reply With Quote
Old 08-30-2013, 10:57 PM   #2
<3MyE36
-Richy Nevaless-
<3MyE36's Avatar
I Should also add that at one point we got it to briefly go into drive and it did drive but now it will not select any gears at all.
Old 08-30-2013, 11:06 PM   #3
I think you already know ALL the possibilities!!! Nobody can tell you more without seeing the car, so just start checking things one by one!!! Start with the shifter, make sure cable is doing the right job, move the selector by hand (at the transmission) and see if that helps. IF not, need a new trans.
Old 08-30-2013, 11:20 PM   #4
<3MyE36
-Richy Nevaless-
<3MyE36's Avatar
Thanks, I will do that, let's say I have a working Transmission from another E36 (which is a 325i) would I be able to use that on the 328i? it is also automatic by the way.
Old 08-30-2013, 11:20 PM   #5
E36is
'OldSchool..'
E36is's Avatar
key in? brake pedal pressed? some transmissions cannot be moved until either or both of those things are done.
Old 08-30-2013, 11:23 PM   #6
<3MyE36
-Richy Nevaless-
<3MyE36's Avatar
We did have the key in and the brake pedal pressed, when we moved it we had to keep the selector in gear 3 instead of drive because that was the only way to get it to work, but now that we have it in the garage it won't go back into park and we can't get the key out of the ignition.
Old 08-30-2013, 11:30 PM   #7
E36is
'OldSchool..'
E36is's Avatar
maybe this will help you find your solution?
Old 08-30-2013, 11:40 PM   #8
No, 325 wont plug in...Even the other 328's wont fit, as they had about 3 different auto transmissions from 96 to 98...Be VERY careful what you buy!
Old 08-30-2013, 11:43 PM   #9
Something is wrong with the cable/selector for sure!!! Not the trans. Start checking that first!
Old 08-30-2013, 11:43 PM   #10
MANDD
Autobahn East
Was the shift lever very difficult to move into RNDL? If so you will need the following....
BMW 25 16 1 423 114 control cable
BMW 24 50 0 429 180 cable clamp - (this may break upon removal)
Mark.
Old 08-31-2013, 12:03 AM   #11
<3MyE36
-Richy Nevaless-
<3MyE36's Avatar
Mark.
Yes it was hard to shift it into RNDL and hard aswell to get it back to Park which its still not in so we just left the key in the off position because we couldn't get it out and disconnected the battery. Thanks a lot I really do appreciate everyone's input my brother and I will try this out tomorrow and let you know how it goes.
Old 08-31-2013, 12:06 AM   #12
<3MyE36
-Richy Nevaless-
<3MyE36's Avatar
I'm praying that you are right, because if you are* we'll be some really happy campers. We will try fixing those problem areas suggested and let everyone know. Thanks again though *sigh of relief*
Old 09-01-2013, 01:45 PM   #13
<3MyE36
-Richy Nevaless-
<3MyE36's Avatar
So after some fiddling around we got the shifter cable out and it was completely broken and corroded, and we could move the selector under the car and it clicks into gear now thanks everyone !!!
Old 09-25-2013, 07:57 PM   #14
<3MyE36
-Richy Nevaless-
<3MyE36's Avatar
UPDATE! : So my brother and I replaced the the shifter cable with a brand new one from the dealer ($165) BUT!, it is very Stiff and difficult to shift into gears it will go into Park, Reverse, Neutral but barely into Drive, 3,2, & 1 also the gear shifter won't click into place, although we did test to see if the the Tranny was good and it is. While we were at it we re-did all the brake lines, bled them and now there is brake resistance (the lines were all leaking), if anyone could HELP it would be greatly appreciated!
Old 09-25-2013, 09:13 PM   #15
MANDD
Autobahn East
Did you replace the cable clamp (BMW 24 50 0 429 180), it may be seized. This part should be free to rotate after the cable is clamped down.
Mark.
Tags
diy, gears, need help, problem, transmission
