Old 08-23-2013, 05:08 PM   #1
LVP
Bleeding/controlling ABS unit
Hi,
Does anyone have access to software/tools to access and control the ABS unit during a brake bleed? I am trying to eliminate the ABS as a source of my soft brake pedal. I would like to be able to:
- Close off all ABS ports to ensure I can get a stiff pedal. If the pedal is still mush, I know the problem lies in the master or ABS unit. If the pedal is hard, I know the problem is past the ABS.
- I'd then like to open each port one at a time to bleed each channel. This way I can systematically firm up each brake channel and get the pedal hard again.
The last two shops I went to weren't really sure how to actually use the software and control the valves. Ideally the dealer software should do it, but my hopes of getting to a mechanic that truly wants to spend the time to fix this while not taking my arm and leg for it are slim.
Anywhere in the Toronto/Niagara/London areas are fine - I can travel if someone has the software to tackle this. If you have the software or know of someone that does, please drop me a note or post.
Thanks.
LVP is offline   Reply With Quote
Old 08-23-2013, 07:47 PM   #2
Ceeker
you could try gravity bleeding the system first going from each wheel furthest to closest to master. Then you can start the car and leave it running to bleed the abs unit. bleed like you would when the car is off. you will of course need someone to pump the peddle for this. Start there and see if there is a change.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 08-25-2013, 09:19 PM   #3
LVP
I tried that without success. I think I got maybe some small bubbles out, but hard to tell. Pumped about a litre through the 4 lines total.
Old 08-25-2013, 10:10 PM   #4
Ceeker
what about disconnecting the power to the abs unit?
Old 08-26-2013, 05:55 PM   #5
LVP
The mush is there with the car on or off, so whether the ABS is powered or not makes no difference. At rest with the car off, the pedal is still long/soft. Makes for an awkward heel/toe at the track. There is no booster (I removed it a while back to see if that was part of the problem - it wasn't)
Old 08-26-2013, 08:48 PM   #6
dcramer
do you have stainless lines ? If not try pinching off all of the brake lines in front of the calipers. If that works then take them off one by one.
If you can't do that then can it be pumped up firm ?
When my pedal was long it firmed up with the car off.
if it is bad on or off I'd seriously start looking at the master cylinder
Old 08-27-2013, 09:30 AM   #7
Cracky
soft brake pedal is pretty common annoyance. nothing more.
Cracky is offline   Reply With Quote
Old 08-27-2013, 09:33 AM   #8
dcramer
Well if it is soft with the engine off I would be worried
Old 08-27-2013, 10:18 AM   #9
Ceeker
well something isn't creating pressure if the pedal is soft after a few pumps with the car off. I'd say it is mechanical then as mentioned - probably master cyl.
question is; how would air get into the abs system to begin with unless the lines were disconnected at the pump? just seems like excessive air in the lines and I can't fathom after bleeding numerous times that you'd still have such a soft pedal.
