Go Back   maXbimmer Forums > Classifieds > For Sale > Drivetrain, Engines & Transmissions
Old 08-22-2013, 05:29 PM   #1
superfl8
superfl8's Avatar
Thumbs up BMW M54 Timing Tools / Camshaft Alignment Tools / Vanos Complete
M54 Timing tools as the titles describes. Tools are for rent at $50 / 24 hours.
-Cam Locks
-Alignment tool
-Alignment Jig
-Tensioner
-Tensioner lock
-Cam Lock
-Air Compressor tool
Ill give the tools free of rent if someone helps diagnose a timing problem I have with my 530i. PM me for details (the tools are fine, i've used them on other cars)
superfl8 is offline   Reply With Quote
Old 04-04-2015, 05:34 PM   #2
netio
Do you still have these tools for rent ?
netio is offline   Reply With Quote
Old 04-04-2015, 05:49 PM   #3
superfl8
superfl8's Avatar
i've got em. I solved my timing issue ages ago though.
shoot me a PM
Old 09-22-2015, 03:08 AM   #4
kosmon
M54 has one problem:
During normal engine operation, vibrations from pressure pulses inside the intake manifold cause the bell crank lever and flapper valve to vibrate against each other where the hex shaped portions contact each other. These vibrations start a wear process which will cause the tiny glass fibers in the flapper valve to become exposed. Once the fibers become exposed they start to erode away the male hex portion of the weaker bell crank lever. As soon as the erosion starts it's all down hill from there until the hex is completely worn away. The symptoms of a worn DISA valve include rough idle, lean engine codes and lack of low to mid rpm power.
If you disassemble a worn out DISA valve and look at the bell crank lever it's common to not even recognize that it once had a hex shape on the protrusion. Once the hex is shape is worn off the lever, the flapper valve no longer opens and closes in a controlled manner by the rotation of the bell crank lever. The brittle flapper valve becomes free to slap around uncontrolled within the DISA support framework. This uncontrolled movement can lead to complete destruction of the flapper valve. The broken pieces of valve have no where else to go except through the intake manifold runners and through the motor, sometimes resulting in severe engine damage. Even a small piece of plastic broken off the flapper valve can hold an intake valve open, resulting in bent valves or much worse.
Since the only parts on the DISA valve that typically fail are the flapper valve, bell crank lever and housing seal, why replace the entire unit. Replace the failed internal parts with these http://vanos-bmw.com/disa-bmw-repair-kits upgraded parts and have a much more reliable DISA for 1/3 the cost.
kosmon is offline   Reply With Quote
Tags
allignment, m54, timing tools, vanos
