Old 11-11-2013, 08:45 AM   #46
captain E34
Sliding Sideways
captain E34's Avatar
Soo i got the car in! Started pulling some small stuff, gunna get deep into it today gunna pull out everything so i can yank the head off, gunna get it ready for mls .120 swap
Sent from my SGH-I747M using Tapatalk
__________________________
1988 535i M30 (Turbo Build)
1989 535i M30 (Beater)
1990 520i Soon To Be S52 (Turbo Build)
1994 525it M50 (Beater)
2005 X5 M64 (Daily)
2009 335i (Daily)
The Rest Is History...
We shall seek who discover mo powa via the wheels (Shakespeare)
QUOTE FROM THE WISE... "Gap is something all the girls want and all the guys want gone"
captain E34 is offline   Reply With Quote
Old 11-11-2013, 08:46 PM   #47
weew379
weew379's Avatar
Oh man, it seems a lot of work, good luck
weew379 is offline   Reply With Quote
Old 11-11-2013, 09:51 PM   #48
captain E34
Sliding Sideways
Got some work done!!, found out e34 suspension is almost identical, i bolted in my old 540 strut housings with h/r sports only issue was the three bolts on the bottom of the strut are larger then the ones in the e28, going to try to swap control arms and lower strut bracket from my 540 left overs
Also got further with the motor tear down, got the intake manifold off!, pain in the ass haha
I have some pics but i will take more
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 11-12-2013, 09:40 PM   #49
captain E34
Sliding Sideways
Took the valve cover off, also sprayed all the nuts and bolts i could think of with some wd, just to ensure i dont break any more bolts,
heres some more pics
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 11-14-2013, 02:22 AM   #50
captain E34
Sliding Sideways
Got a little deeper today!
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 11-14-2013, 02:28 AM   #51
captain E34
Sliding Sideways
I also started swapping rear struts, for my e34s, and saw the mounts have different bolt patterns, and mount sizes are different, since i want to do a complete e34 suspension swap, im going to bore out my strut towers, and drill new bolt holes, the car has some minor rust in the strut towers that i am going to repair
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 11-14-2013, 02:30 AM   #52
captain E34
Sliding Sideways
My parts from tcd will arrive next week or so
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 11-14-2013, 11:34 PM   #53
captain E34
Sliding Sideways
Got into cleaning/polishing the block surface with 2000 grit and finishing off with 3000 , nice and clean, smooth and no left overs from the old headgasket, tomorrow im onto the head to clean that up hoping my parts will be here nxt week!
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 11-15-2013, 01:53 AM   #54
buzzdmonkey
engine looks brand new on the inside.
buzzdmonkey is offline   Reply With Quote
Old 11-15-2013, 01:55 AM   #55
buzzdmonkey
oh yeah, i also had an idea for the rear suspension. if this makes any sense lol. look at the 3 bolts on the top as a triangle, could you not just flip the triangle and re-drill new holes? im thinking it would be a bit more structural that way. it makes sense in my head lol
Old 11-15-2013, 08:48 AM   #56
captain E34
Sliding Sideways
U mean re drill new wholes into the strut mounts? Instead of the body?
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 11-15-2013, 11:41 AM   #57
buzzdmonkey
is hard to explain lol, we gotta chill soon itll be easier to explain in person
Old 11-15-2013, 11:46 AM   #58
captain E34
Sliding Sideways
haha well i plan on re drilling the strut tower for the e34 bolt pattern so i don’t have to drill every
time i swap struts, the "triangle" for the e34 struts is smaller then the e28's,
i wish i had a e28 rear strut mount so i can try seeing if the e34 coil will fit in the e28 mount before i drill mine are to rusty and bent up to get an accurate "reading"
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 11-21-2013, 04:30 PM   #59
captain E34
Sliding Sideways
i ordered a few things!! some gauges, wide band a/f, egt, and boost/vac, looking into a mspnp from diyautotune.com, ordered exhaust manifold studs, intake gaskets, coolant hoses, oil pan gasket, valve cover gasket, spark plugs and probably some other things im sure i forgot....
i was talking to todd at tcd and he mentioned that the optimal c/r for the m30 is 8:1, the mls i ordered which was .10" is to thick and will lower my c/r to about 7.4, my friend who has an m30b35 is going to purchase my .120 and im going to re-order an .08 which is stock thickness. ill take pics of everything when its in
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 11-28-2013, 12:37 AM   #60
captain E34
Sliding Sideways
After contacting diy autotune about a mspnp for a #059 ecu we came to the conclusion... they dont have one haha, so the only option for me was to wire ms3x (preassembled) into my stock harness, so thats wat i plan on doing, i ordered ms3x, with all the wiring harnesses and sensors ill need to complete the install, ill make a list when the items come in!
I got my items from tcd!,
2005 X5 M64 (Daily)
2009 335i (Daily)
