Old 08-15-2013, 12:47 PM   #1
kamus
Life begins at 4000rpm
kamus's Avatar
Suspension upgrades
Can you folks educate me on suspension choices for E30 track use? Assume that I'm all stock for now except for Toyo R888's. Links to old threads much appreciated!
I attend 7 or 8 Driving Schools per year at Mosport. I'm in the advanced group, but a couple E30's and one pesky 2002 (you know who you are) always get by me! Car is super fast but leaning a LOT thru all turns, and the rear bounces a LOT through turn 3.
I looked through all the options that Turner Motorsport offers for springs, shocks and packages. Which of those would you consider, and what are the other alternatives I should look at?
Cheers!
PS - x-posting to Track Junkies
kamus is offline   Reply With Quote
Old 08-15-2013, 01:15 PM   #2
Roysneon
Roysneon's Avatar
So you have stock springs and dampers now? What is it you're looking for? Seems you have enough experience to know if you need more spring rate, heavier dampers, different front-rear balance, etc. There are many commonly used suspension setups that people say are 'good' but it depends on what you feel the car could benefit from.
Old 08-15-2013, 11:10 PM   #3
goldhawk
Is your car a daily driver as well?
Whats your budget like?
Do you want to get sway bars too, or just springs/dampeners?
goldhawk is offline   Reply With Quote
Old 08-16-2013, 12:02 AM   #4
Might be stating the obvious, but; the best, most adjustable coilovers you can get!? So you can set up the car JUST the way you need it. After that would be sway bars, strut bars, (and assuming you already did ALL other work such as bushings, mounts, ball joints, etc!).
Old 08-16-2013, 08:50 AM   #5
food
Custom User Title
food's Avatar
Not sure the expense at this point is really necessary. Coming from stock you will notice a huge different no matter if its a $5000 or a $1000 setup.
I would suggest H&R race springs and Bilsteins valved for your weight and spring rate. These are good quality parts that are serviceable and will far outlast the cheap coilovers, still provide a huge upgrade over stock.
Maybe add ground control type coilover sleeves if you really want adjustable ride height or want to corner balance the car.
Lots of people want the fancy dampers with 32 settings for both rebound and compression but do you really think you can pick the perfect setting out of 1024 possible combinations?
food is offline   Reply With Quote
Old 08-17-2013, 07:36 AM   #6
richie_s999
look into the turner J stock suspension, it will out perform any other "race" spring and has the best match valves Billy's available for the springs.
Ninja edit, see this has been posted in multiple sections lol
Old 08-17-2013, 04:30 PM   #7
E30Jack
anything would be an upgrade from worn stock suspension. if i were you i'd start looking into coilovers. megans, gc, etc. you can get custom coilovers from Ground Control but they're a bit spendy.
E30Jack is offline   Reply With Quote
Old 08-18-2013, 10:49 AM   #8
kamus
kamus's Avatar
Thanks for all the suggestions guys. I duplicated my original posting to Track Junkies, and got a bunch of replies there as well - along similar lines I might add. Probably better to continue the discussion in one spot rather than both, so please see my response and further questions over there: http://www.maxbimmer.com/forums/showthread.php?t=159341
Old 08-20-2013, 08:57 AM   #9
Roysneon
Roysneon's Avatar
WAT. No.
Old 08-20-2013, 02:56 PM   #10
E30Jack
If he's trying to track then yes pretty much any set up would be an upgrade from worn out stock suspension & you've never used Megan's if you don't like them, they're the tits
Old 08-21-2013, 07:47 AM   #11
Roysneon
Roysneon's Avatar
Right on there, Senna.
Old 08-21-2013, 09:14 AM   #12
frankie591
LMAO so are you gonna put jom coilovers on your track car??
Old 08-21-2013, 01:00 PM   #13
E30Jack
Frankie obviously you'd go with the highest quality suspension, but if I had a choice between JOM and stock, then I'd go with JOM. Stock body roll is killer
