Old 08-08-2013, 09:03 PM   #1
aberg83
aberg83's Avatar
Would this work for wheel bearing removal?
http://www.princessauto.com/pal/Pull...ller/8105256.p
aberg83 is offline   Reply With Quote
Old 08-08-2013, 09:46 PM   #2
mr ilia
Front or rear?
For the front you do not need one really, but it can be useful if you do not have dremel.
Wouldn't you be able to rent something similar from Canadian Tire?
Old 08-09-2013, 10:31 AM   #3
karmatose
164.3ci Of Fury
karmatose's Avatar
For the front, just remove the rotor and caliper and use the wheel as a slide hammer to remove the front hub. The inner race will probably stick behind on the spindle, but you can knock that off with a chisel and hammer (or air hammer if you have a compressor).
Rear, I bought this: http://www.harborfreight.com/fwd-fro...ers-66829.html
The threaded rod is a bit cheesy, but it works great. You could probably make your own from various bits in Home Depot for a lot less though.
"She may not look like much, but she's got it where it counts, kid. I've made a lot of special modifications myself. " - Han Solo
Old 08-09-2013, 11:11 AM   #4
Steve30
Techno Viking
Steve30's Avatar
You can just rent the kit for free from parts source for the rear. My rear wheel bearing is toast on the 320... Need to replace it before I go insane. Its so loud.
E36 ///M3 S54
STock 335i
Old 08-09-2013, 12:54 PM   #5
aberg83
aberg83's Avatar
You mean parts source has a similar kit to the harbor freight one for rental?
Old 08-09-2013, 01:17 PM   #6
Steve30
Techno Viking
Steve30's Avatar
yes
E36 ///M3 S54
STock 335i
Old 08-09-2013, 01:19 PM   #7
aberg83
aberg83's Avatar
Originally Posted by Steve30 View Post
yes
Score! Good to know. Hopefully they can also rent a bearing separator, bubble flare kit and cutting tool for brake lines. I'd like to avoid buying tools that I'll only use once or twice.
